ZAON PCAS MRX
Old December 12th 13, 02:54 AM posted to rec.aviation.soaring
Nick Kennedy
Default ZAON PCAS MRX
Are these units reliable and worth having in your glider?
Are they consistent enough to trust in a real threat situation?
Nick
Old December 12th 13, 03:30 AM posted to rec.aviation.soaring
6PK
Nick
It is very reliable BUT has major limitations;
It will tell you that there is a possible threat(s), the distance and if it is above or below and the respective number of feet. What it does not indicate is the direction. I find my head turning more vigorously than normal when it goes off which is a good thing.
Old December 12th 13, 03:36 AM posted to rec.aviation.soaring
Vaughn
No present collision avoidance technology should be considered
"reliable". It's just there as a backup to your MK1 eyeball.
I own one, and I consider it "worth having", meaning that it beats
having nothing. Since I own it, I don't fly without it.
Again, you should only trust your eyes. The MRX is there to nudge you
if your scan misses something. (When you get one, you will be surprised
and embarrassed at how unreliable your scan is.)
Vaughn
Old December 12th 13, 04:52 PM posted to rec.aviation.soaring
Dan Marotta
What they both said...
Besides the fact that it alerts you to pick up your scan, you can quickly
interpret whether an aircraft might be a threat by observing whether it's
closing with you. Just because range or altitude are closing does not mean
that it's a threat, but I'm more concerned with a closing aircraft than one
that's opening the gap.
What nobody has said is that it's a battery hog. A pair of AA batteries may
not last for a single flight so I've hooked mine up to ship's power.
"Vaughn" wrote in message
No present collision avoidance technology should be considered "reliable".
I own one, and I consider it "worth having", meaning that it beats having
Again, you should only trust your eyes. The MRX is there to nudge you if
your scan misses something. (When you get one, you will be surprised and
Vaughn
Old December 12th 13, 04:55 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
Nick
Mine seems to be reliable. Seems to pick up relevant traffic. Ignores
airliners way up in the flight levels and I have had it ignore aircraft
passing at very low altitudes such as powerline patrols. Maybe the
software ignores them or they were too low for their transponders to be
interrogated. Can be annoying at during the launch at contest sites as
the towplanes are continually causing it to bleep.
--- news://freenews.netfront.net/ - complaints: ---
Old December 12th 13, 05:46 PM posted to rec.aviation.soaring
Nick
No! I had to send back my MRX to Zaon 3 times because a "filter" kept going out. The problem was the unit would not tell me there was any problem. It just acted like everything was fine but it would just stop picking up any other aircraft. I knew it was bad when a jet or two would get too close and it didn't pick it up. Very frustrating!
Also, please be aware that Zaon is now out of business so when that filter on yours goes out you might not have anywhere to send it to. Here is a link about them going Tango Uniform. http://www.avweb.com/avwebflash/news...n220938-1.html
The best solution is get a PowerFlarm, but then again, I know you don't like to be told what to do... Looking forward to flying with you next year..
Bruno - B4
Old December 12th 13, 06:08 PM posted to rec.aviation.soaring
Nick
I have had the same experience as Bruno. The MRX works well when it works, but mine has been back to the manufacturer 3 times for repair, and it's ready for it's fourth repair. This time, there's no manufacturer to send it back to. If I could get it fixed again, I'd do it. Is the unit reliable? No.
Russ
Old December 12th 13, 07:24 PM posted to rec.aviation.soaring
Does that mean that the only way to get PCAS functionality now is via PowerFlarm? I did a search and it seems that Zaon was the only other company making PCAS (it's their term so I'm wondering if the same capability is available under another name). True?
9B
Old December 13th 13, 04:12 PM posted to rec.aviation.soaring
Nick Kennedy
Hi Gents
Thanks for the good information on the MRX, I appreciate the time you guys took to write about it.
It sounds like when it is working and connected to the ships power it is a good thing to have on board.
I got mine in my extra's box of stuff when I purchased glider T and it seems to work at the present.
I set it on the dash of my F150 truck looking at the turns from downwind to base to final here in Telluride yesterday at it worked as advertised, and I could read the screen in bright sunlight
I like how simple it is to use and how easy it is to interpret the display. To bad they went Tango Uniform as Bruno so delicately put it :]
Happy Holidays
Nick
T
Nick
Old December 13th 13, 07:19 PM posted to rec.aviation.soaring
Dan Marotta
I've had mine for less than a year and, so far, it has not failed.
As to extremely high or low aircraft alerting - during setup the pilot
chooses maximum range and altitude difference to report.
"Nick Kennedy" wrote in message
Hi Gents
Happy Holidays
Nick
T
Nick
FS: PCAS Zaon MRX [email protected] Soaring 2 November 27th 13 11:36 PM
FS: Zaon MRX PCAS Ramy Soaring 8 August 8th 13 07:09 AM
Fs Zaon Pcas Xrx cessna150 Aviation Marketplace 0 January 26th 12 07:02 AM
Warning to users of Zaon PCAS MRX Bruno[_2_] Soaring 23 February 22nd 10 06:04 PM
GPS intrference from Zaon PCAS ?? Carl Soaring 9 May 31st 07 06:12 AM
