Grob gliders, new TM about control system pulleys
Old February 5th 14, 09:14 PM posted to rec.aviation.soaring
Robert M
Default Grob gliders, new TM about control system pulleys
5 Feb. 2014
A Tech Note for Grob gliders has recently been issued by the Type Certificate holder, Fiberglas_Technik, Rudolf Lindner of Germany.
TM-G05 Calls for the replacement of the 42mm diameter white or brown plastic pulleys with aluminum ones. The plastic ones crack. This applies to several versions of the G-102 and G-103 gliders.
The pulleys are found on rudder pedals and front mounted tow hooks. Over the last 10 years or so I have replaced several sets of these pulleys. About 75% of the ones I look at are cracked.
The EASA has issued an AD note for this, (AD 14-027). It is highly likely that the FAA will issue an AD note. This concerns a control system and the plastic pulleys have broken. There is no doubt in my mind an FAA AD will be issued.
There are two time lines for replacement depending on how the pulleys are mounted.
I strongly urge US, Canada and Mexico based Grob owners to read and understand the TM. It is available at http://ltb-lindner.com/g-103-ad-sb.html .
I'll be ordering some pulleys but it would be good to know how many owners will need them.
Robert Mudd
Composite Aircraft Repair LLC
Moriarty, New Mexico
Come for the thermals, stay for the sunsets
Grob Fuselage FLight Control Cover [email protected] Soaring 0 June 8th 08 02:52 AM
Booking system for gliders AndersP Soaring 10 March 19th 08 04:44 PM
latest control system! Jordz Piloting 0 July 23rd 07 03:48 PM
sim cockpit control system El Baron Rojo Simulators 0 July 28th 05 10:32 PM
Control cables for gliders mike maskell Soaring 10 January 1st 04 06:08 AM
