GPS Data inside SSA Convention Hall
Old February 22nd 14, 01:21 AM posted to rec.aviation.soaring
Paul Remde
Default GPS Data inside SSA Convention Hall
Hi,
I have a technical question. Next week at the SSA Convention many vendors
(myself included) will have many soaring instrument demos on display. It
would be great if they could be locked onto GPS satellites, but that is not
likely inside the convention hall. I imagine the roof is made of metal.
The moving map displays will display more interesting information when
locked onto satellites. Also, the all the FLARM units in the room would
show up on the moving map displays - but only if the FLARMs and the moving
map displays are locked-onto GPS satellites.
Is there a technical solution to that issue? Could a receiver be mounted
somewhere that receives, amplifies or re-directs and rebroadcasts the GPS
signals for use inside the hall?
I have no idea if that is possible, easy or difficult.
Any thoughts?
I imagine it is too late to get that working for the SSA Convention this
year, but it doesn't hurt to ask.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old February 22nd 14, 02:10 AM posted to rec.aviation.soaring
son_of_flubber
http://www.gpssource.com/GPS-Retransmission
Old February 22nd 14, 06:23 AM posted to rec.aviation.soaring
Alan[_6_]
In article "Paul Remde" writes:
Hi,
However, all of the receivers will show position computed at the location
of the outside receiver antenna, with time offset by the delay through the
system and the inside path.
The FLARM units will show everyone in the same place.
Also, from the separately referenced http://www.gpssource.com/GPS-Retransmission:
The FCC regulates the GPS signal. Retransmission systems are only
available to International Customers (outside the U.S.), agencies of the
US Federal Government, parties operating under the direction of the US
Federal Government, or parties that have received an STA or Experimental
License under part 5 of the FCC rules, or parties that will be operating
GPS Repeaters in an anechoic chamber.
Alan
Old February 23rd 14, 08:56 PM posted to rec.aviation.soaring
JS
As a test, left the ClearNav on during the drive home yesterday.
Got a good trace for the entire route, in a metal top trailer.
Surprised.
Stan Hall passed away this morning - SSA Hall of Fame member Dan Armstrong Soaring 6 September 12th 09 11:41 PM
Digital airspace data question -- any FAA data gurus out there? Tuno Piloting 2 December 27th 07 06:06 PM
EAA U/L Hall of Fame Frank Beagle Home Built 0 January 27th 07 10:36 PM
Flight Data recorders on a 757 - What data? Al Dykes General Aviation 0 January 1st 07 06:09 PM
