A polar calculation question for you number crunching enthusiasts out there
Old February 23rd 14, 11:49 PM posted to rec.aviation.soaring
ES
Default A polar calculation question for you number crunching enthusiasts out there
I'm trying to use Paul Remde's very handy "Reichmann to Cambridge and SeeYou" spreadsheet to derive some usable SeeYou polar numbers for my Diana-1. But I'm having a heck of a time picking three speed/sink-rate pairs from the data set that result in Max L/D and Best Glide Speed numbers that pass the sniff test.
For example, I can enter 3 pairs of values from early, middle, and late in the data set, and it tells me I have a max L/D of 49 (wouldn't that be nice!) at ... 38 km/h. Uh, that's well below stall speed!
Is there any conventional wisdom on this?
Are there any other tools available that can take a set of sink rates (hopefully more than 3) and produce some decent numbers?
Wishing the flight computers would just start with lookup tables,
tuno/ES
Old February 24th 14, 02:08 AM posted to rec.aviation.soaring
Tim Taylor
Ted,
Does the rest of the curve look like a reasonable match to the polar? If so that is likely good enough. You are not going to use a speed to fly to fly too slow. You will only fly down to best l/d speed anyway.
If you really want to force the lower portion of the curve you need to use more pairs of points and likely will need to go to a third or fourth order polynomial. The problem is most flight software is designed around the second order fit.
Tim
Old February 24th 14, 02:15 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default A polar calculation question for you number crunching enthusiastsout there
ES wrote, On 2/23/2014 3:49 PM:
speed!
Put in the values for an ASW 27. If after flying a few flights that
seems to pessimistic, put in the values for the next step up. Accuracy
in the polar isn't important to success.
email me)
Old February 24th 14, 02:27 AM posted to rec.aviation.soaring
ES
Accuracy in the polar isn't important to success.
Your position is stipulated -- my OP is ONLY about the accuracy of the polar.
Old February 24th 14, 02:58 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default A polar calculation question for you number crunchingenthusiasts out there
Does your flight computer accept polars in the Winpilot format?
If so, are the numbers for an SZD-56-2 Diana-2 of any use, either
directly or for use as a starting point? If so the SZD-56-2 polar is
included on the LK8000 polars database.
Well, both XCsoar and LK8000 do just that and both load polars from
Winpilot format polar files, - but neither currently has a polar for the
SZD-56-1 Diana-1.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 24th 14, 01:15 PM posted to rec.aviation.soaring
ES
I'm using SeeYou Mobile with an LXNAV V7. Both take polars in the same form: stall speed, A, B, and C coefficients, min (wing) loading, min weight, max weight, empty weight, and pilot weight.
I'm also confused about the weights. If "pilot weight" is provided, then I can only assume "empty weight" means just the glider without the stick actuator, but why would the computer care about that? Why not just "dry take-off weight"?
Old February 24th 14, 02:26 PM posted to rec.aviation.soaring
Hmmm...
Do they have provision for different pilot profiles to fly the glider?
Old February 24th 14, 03:58 PM posted to rec.aviation.soaring
Mike the Strike
You could also throw Dick Johnson's polar test data into an Excel spreadsheet and do a curve fit - that might be a good starting point.
Old February 25th 14, 10:20 AM posted to rec.aviation.soaring
David Salmon[_3_]
SZD-56-1 Diana-1.
org |
To add to what Martin says, LK8000 (don't know about XCS), has the facility
to add the wing area field to the polar file. You can then set your wing
loading, for actual flight, and the polar will be adjusted automatically.
Dave
Old February 25th 14, 01:13 PM posted to rec.aviation.soaring
Bryan Searle
SZD-56-1 Diana-1.
org |
facility
Dave
Use the excellent polar spreadsheets buy Paul Remde he
http://www.cumulus-soaring.com/soarmn/soaring_files.htm
Tables are not used by LK8000, and the quadratic approximations are not a
great way to do it, look-up would be much better!
contest number question Gary Emerson Soaring 22 February 9th 18 04:15 PM
SeeYou task leg distance calculation question Tuno Soaring 6 April 19th 11 10:08 PM
New Chance for Aviation Enthusiasts MOD Piloting 0 February 26th 07 05:42 PM
Pitts Number 1 registration number Mirco Aerobatics 3 December 4th 04 11:50 AM
N number question Chuck Piloting 3 October 23rd 03 07:17 PM
