IGC Logger V2.07 is available
Old March 20th 14, 02:46 PM posted to rec.aviation.soaring
Default IGC Logger V2.07 is available
Here's the latest IGC logger version. The changes a
Adds 'start time' to the criteria for finding duplicates. This solves the problem of multiple flights on the same day from the same location being identified as dupes.
Addresses the problem of not being able to scroll the log to verify that the dupes identified by the program really are duplicates. It does this by not removing the highlighting if you say 'No' or 'Cancel' to the dialog box. This leaves the proposed dupes highlighted for you to check. Then I added a separate button to clear the highlighting, if desired.
Changed the 'Stats' code slightly so the '12 Month' date cell now defines the start of a 12-month window. You can get the stats for *any* 12-month window by simply editing this cell to be the desired start date. Then the code searches the log for any flight with a date that fits between the displayed start date and 12 months after that date.
Added an 'Import' feature so you can import a log from any earlier version of IGC Logger to the current one
The new version can be downloaded from my Google Drive site at
https://drive.google.com/file/d/0BwI...it?usp=sharing
Frank (TA)
logger rec.aviation.soaring[_2_] Soaring 1 June 26th 11 12:57 PM
3D Logger sisu1a Soaring 0 June 27th 10 06:23 PM
EW Logger [email protected] Soaring 10 January 9th 09 10:30 PM
Looking for a Logger [email protected] Soaring 0 August 3rd 06 06:47 PM
Ted, your LX logger......... [email protected] Soaring 6 June 26th 06 05:21 PM
