Reagan and AF"1"
Old June 12th 04, 05:22 PM
kage
Default Reagan and AF"1"
On the topic of President Reagan.
After he ordered the Boeing 747's as new Air Force One's, his first two
rides in them were in his CASKET.
Best,
Karl
"remote from Chicago"
Old June 13th 04, 01:38 AM
Marty
"kage" wrote in message
Best,
Karl
Yeah, but think about it. It still wasn't technically AF "1" without G'
DUBBYA on board!
Old June 13th 04, 08:33 PM
Robert M. Gary
They mentioned on the news that it was not really "Airforce 1" because
Bush did not fly out to California too.
"Marty" wrote in message news:5vMyc.78
Best,
Karl
DUBBYA on board!
Old June 14th 04, 02:48 AM
Marty
m...
Robert,
Thanks for the clarification. I didn't see that portion of the events myself
but my Dad insisted they called it "AF1".
I just said OK to avoid another senseless argument between us.
Marty
Old June 14th 04, 11:33 AM
Cub Driver
I'm sure your dad was right, and that "they" -- the newscasters --
called it Air Force One.
The idea that a plane could have a different name, depending on the
passenger, is not one that is easily grasped. It's like having an
ocean liner that's called the QE II only when the queen is on board.
It must be particularly stressful when Air Force One becomes Air Force
Two.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! www.vivabush.org
Old June 14th 04, 03:18 PM
tony
Two.
way back when I took PPL training at East Coast Aerotech at Hanscom AFB (BED)
their training airplanes were called something like Tech 1, Tech 7, or
whatever, not by their N numbers.
Airliners under air traffic control identify themselves by their flight
numbers.
In the case of training flights, it surely alerted the tower people the
aircraft was probably being driven by a student, and instructions like
"expidite approach" would be inappropiate.
In the case of "Air Force One" it more likely means to controllers that nota
all aircraft are created equal. AF 1 is number one to land from 50 miles out!
I'll bet they don't often get told to take a 360 for spacing!
AJW
Old June 14th 04, 04:18 PM
Steven P. McNicoll
"tony" wrote in message
nota all aircraft are created equal. AF 1 is number one to land from 50
miles out! I'll bet they don't often get told to take a 360 for spacing!
ATC services are provided on a first come, first served basis, with a few
exceptions. Presidential aircraft are given priority over most other
aircraft, but not all other aircraft. Top priority is given to aircraft in
distress, and if it was deemed necessary for A1 to do a 360, A1 would be
given a 360.
FAA Order 7110.65P Air Traffic Control
Chapter 2. General Control
Section 1. General
2-1-4. OPERATIONAL PRIORITY
Provide air traffic control service to aircraft on a "first come, first
served" basis as circumstances permit, except the following:
NOTE-
It is solely the pilot's prerogative to cancel an IFR flight plan. However,
a pilot's retention of an IFR flight plan does not afford priority over VFR
aircraft. For example, this does not preclude the requirement for the pilot
of an arriving IFR aircraft to adjust his/her flight path, as necessary, to
enter a traffic pattern in sequence with arriving VFR aircraft.
a. An aircraft in distress has the right of way over all other air
traffic.
REFERENCE-
14 CFR Section 91.113(c).
b. Provide priority to civilian air ambulance flights "LIFEGUARD." Air
carrier/taxi usage of the "LIFEGUARD" call sign, indicates that operational
priority is requested. When verbally requested, provide priority to military
air evacuation flights (AIR EVAC, MED EVAC) and scheduled air carrier/air
taxi flights. Assist the pilots of air ambulance/evacuation aircraft to
avoid areas of significant weather and turbulent conditions. When requested
by a pilot, provide notifications to expedite ground handling of patients,
vital organs, or urgently needed medical materials.
NOTE-
It is recognized that heavy traffic flow may affect the controller's
ability to provide priority handling. However, without compromising safety,
good judgement shall be used in each situation to facilitate the most
expeditious movement of a lifeguard aircraft.
c. Provide maximum assistance to SAR aircraft performing a SAR mission.
REFERENCE-
FAAO 7110.65, Providing Assistance, Para 10-1-3.
d. Expedite the movement of presidential aircraft and entourage and any
rescue support aircraft as well as related control messages when traffic
conditions and communications facilities permit.
NOTE-
As used herein the terms presidential aircraft and entourage include
aircraft and entourage of the President, Vice President, or other public
figures when designated by the White House.
REFERENCE-
FAAO 7110.65, Aircraft Identification, Para 2-4-20.
FAAO 7110.65, Departure Clearances, Para 4-3-2.
FAAO 7210.3, Advance Coordination, Para 5-1-1.
e. Provide special handling, as required to expedite Flight Check
aircraft.
NOTE-
It is recognized that unexpected wind conditions, weather, or heavy
traffic flows may affect controller's ability to provide priority or special
handling at the specific time requested.
REFERENCE-
FAAO 7110.65, Flight Check Aircraft, Para 9-1-3.
f. Expedite movement of NIGHT WATCH aircraft when NAOC (pronounced
NA-YOCK) is indicated in the remarks section of the flight plan or in
air/ground communications.
NOTE-
The term "NAOC" will not be a part of the call sign but may be used when
the aircraft is airborne to indicate a request for special handling.
REFERENCE-
FAAO 7610.4, Applications, Para 12-1-1.
g. Provide expeditious handling for any civil or military aircraft using
the code name "FLYNET."
REFERENCE-
FAAO 7110.65, FLYNET, Para 9-3-6.
FAAO 7610.4, "FLYNET" Flights, Nuclear Emergency Teams, Para 12-4-1.
h. Provide expeditious handling of aircraft using the code name "Garden
Plot" only when CARF notifies you that such priority is authorized. Refer
any questions regarding flight procedures to CARF for resolution.
NOTE-
Garden Plot flights require priority movement and are coordinated by the
military with CARF. State authority will contact the Regional Administrator
to arrange for priority of National Guard troop movements within a
particular state.
i. Provide special handling for USAF aircraft engaged in aerial sampling
missions using the code name "SAMP."
REFERENCE-
FAAO 7110.65, SAMP, Para 9-3-15.
FAAO 7210.3, Atmosphere Sampling For Nuclear Contamination, Para 5-3-4.
FAAO 7610.4, Atmospheric Sampling For Nuclear Contamination, Para 12-4-3.
j. Provide maximum assistance to expedite the movement of interceptor
aircraft on active air defense missions until the unknown aircraft is
identified.
k. Expedite movement of Special Air Mission aircraft when SCOOT is
indicated in the remarks section of the flight plan or in air/ground
communications.
NOTE-
The term "SCOOT" will not be part of the call sign but may be used when
REFERENCE-
FAAO 7110.65, Law Enforcement Operations by Civil and Military
Organizations, Para 9-3-10.
FAAO 7610.4, Applications, Para 12-7-1.
l. When requested, provide priority handling to TEAL and NOAA mission
aircraft.
NOTE-
Priority handling may be requested by the pilot, or via telephone from
CARCAH or the 53rd Weather Reconnaissance Squadron (53WRS) operations center
personnel, or in the remarks section of the flight plan.
REFERENCE-
FAAO 7110.65, Weather Reconnaissance Flights, Para 9-3-17.
m. IFR aircraft shall have priority over SVFR aircraft.
REFERENCE-
FAAO 7110.65, Chapter 7, Section 5, Special VFR (SVFR).
n. Providing priority and special handling to expedite the movement of
OPEN SKIES observation and demonstration flights.
NOTE-
An OPEN SKIES aircraft has priority over all "regular" air traffic.
"Regular" is defined as all aircraft traffic other than:
1. Emergencies.
2. Aircraft directly involved in presidential movement.
3. Forces or activities in actual combat.
4. Lifeguard, MED EVAC, AIR EVAC and active SAR missions.
REFERENCE-
FAAO 7110.65 OPEN SKIES Treaty Aircraft, Para 9-3-20.
FAAO 7210.3, OPEN SKIES Treaty Aircraft, Para 5-3-7.
Treaty on OPEN SKIES, Treaty Document, 102-37.
o. Aircraft operating under the North American Route Program (NRP) are not
subject to route limiting restrictions (e.g., published preferred IFR
routes, letter of agreement requirements, standard operating procedures).
REFERENCE-
FAAO 7110.65, En Route Data Entries, Para 2-3-2.
FAAO 7110.65, North American Route Program (NRP) Information, Para 2-2-15.
FAAO 7110.65, Route or Altitude Amendments, Para 4-2-5.
FAAO 7210.3, Chapter 17, Section 17, North American Route Program.
p. If able, provide priority handling to diverted flights. Priority
handling may be requested via use of "DVRSN" in the remarks section of the
flight plan or by the flight being placed on the Diversion Recovery Tool
(DRT).
REFERENCE-
FAAO 7210.3, Diversion Recovery, Para 17-4-6.
Old June 14th 04, 05:27 PM
tony
I did hedge a little saying A1 wouldn't often be given a 360. I wasn't thinking
of an aircraft in trouble, thanks for giving a reasonable example.
Old June 14th 04, 08:11 PM
Robert M. Gary
"Marty" wrote in message ...
m...
Robert,
Its also little known that "Airfoce 1" is not really A plane. There
are a fleet of planes operated by the president's Airforce
transporation squadron. There are little jets for trips to the vinyard
and medium jets for medium trips to shorter runways. However, everyone
thinks of the 747 (of which there are actually 2). Airforce 1 does not
travel alone either. There are a fleet of C130's that carry things
like the motorcade (the president doesn't need to wait for a rental
car, he brings his bullet proof car with him.
-Robert
Old June 14th 04, 08:22 PM
Shiver Me Timbers
Airforce 1 does not travel alone either.
like the motorcade
Curious question to the group.
Anyone know how much it costs for all of this
infrastructure and support staff etc. to travel
from one location to another.
