Lithium 3.6 Battery
Old April 20th 14, 02:42 PM posted to rec.aviation.soaring
HGXC[_3_]
Default Lithium 3.6 Battery
After a long trip towing my glider I was going thru the cockpit and on the floor I discovered a Lithium battery in a black plastic holder on the floor near the instrument panel, (I hate when that happens).
The battery is about th same size as a AA and i have no idea where is came from or goes. No sign of any breakage with the plastic holder. All instruments, radio and warning devices are working.
Any ideas?
HGXC
Old April 20th 14, 03:35 PM posted to rec.aviation.soaring
Some varios have a small back up battery that is mounted outside the vario by the owner, often not mounted well enough. (ex: B40 uses a 9V).
Old April 20th 14, 04:11 PM posted to rec.aviation.soaring
Any ideas?
HGXC
Quantum tunneling from another universe?
Old April 20th 14, 07:24 PM posted to rec.aviation.soaring
Kevin Neave[_2_]
OK, give us a clue, what instruments do you have in your panel?
It's unlikely to have come from a Winter vario, ASI or Altimeter.
KN
floor
came
Any ideas?
HGXC
Old April 20th 14, 07:35 PM posted to rec.aviation.soaring
HGXC[_3_]
KN
floor
came
Any ideas?
HGXC
Winter and Sage varios, Lnav with Cambridge GPS, Becker Radio. All instruments and radio work and the LNAV has a internal disk back up battery.
HGXC
Old April 20th 14, 07:38 PM posted to rec.aviation.soaring
HGXC[_3_]
KN
floor
came
Any ideas?
HGXC
HGXC
also.... a14 with Flow meter and Canula Oxygen syst.
HGXC
Old April 21st 14, 02:07 AM posted to rec.aviation.soaring
Mark628CA
Pacemaker?
Old April 21st 14, 04:13 AM posted to rec.aviation.soaring
Brian[_1_]
Is the Becker remembering the preset frequencies when turned off for an extended period of time. If it is not remembering them, It might be someone replaced the internal battery with an external one.
Brian
Old June 4th 14, 04:04 PM posted to rec.aviation.soaring
HGXC[_2_]
Brian
Brian you hit it on the head. I couldn't solve the issue until i flew the glider at a different airport and went to put in new presets and they were lost after i turned the radio off. I then contact the former owner and he said there was a battery in the wiring behind the radio. Have you seen this before? Any advice as to where i might find where the battery went? I won't see the glider again until this weekend.
Dennis
Nonflammable lithium batteries Ron Gleason Soaring 0 February 12th 14 03:08 AM
Lithium Batteries Orval Fairbairn[_2_] Piloting 21 October 17th 10 11:21 PM
Still interested in Lithium batteries for your glider? Eric Greenwell Soaring 5 March 5th 05 03:32 PM
Lithium technology batteries Ken Kochanski (KK) Soaring 24 December 25th 04 06:40 AM
