Steep turns without yoke?
Old July 7th 04, 05:23 PM
Roger Long
Default Steep turns without yoke?
A friend of mine's IFR instructor showed him something I've never heard of.
He rolled in 2 - 3 turns of nose up trim on our 172, pushed on a rudder
pedal, and went into a nice level steep turn without touching the yoke. I'm
not sure if this is practice for proper turn entry or a way of entering an
emergency turn partial panel without the danger of over banking.
Can anyone shed further light on this maneuver?
Roger Long
Old July 7th 04, 05:49 PM
Bob Gardner
My only problem with it is that when you have to do two steep turns
back-to-back you must be ready with lots of forward pressure as you roll
through wings-level...if you are not anticipating it you can gain a couple
of hundred feet in a heartbeat.
Bob Gardner
"Roger Long" wrote in message
of.
I'm
Roger Long
Old July 7th 04, 05:59 PM
pilot
Pretty easy to do with a little practice... all about rudder contro
and knowing how to trim a plan
pilo
http://www.pilotboard.com I love this place
pilot's Profile: http://www.pilotboard.com/forums/mem...etinfo&userid=
View this thread: http://www.pilotboard.com/forums/sho...p?threadid=314
Old July 7th 04, 10:05 PM
Bob Gardner
Didn't say it was hard, just that it should be anticipated.
Bob Gardner
"pilot" wrote in message
news
Pretty easy to do with a little practice... all about rudder control
and knowing how to trim a plane
pilot
http://www.pilotboard.com I love this place!
pilot's Profile:
http://www.pilotboard.com/forums/mem...tinfo&userid=1
View this thread:
http://www.pilotboard.com/forums/sho...?threadid=3141
Old July 7th 04, 10:27 PM
john smith
Electric trim would simplify the process.
Old July 7th 04, 11:21 PM
Dave S
Steep turns and partial panel are a bad combination. I would consider
this a demonstration of what you can do with rudder and trim, and an
example of skill at controlling the airplane.
In smooth air, VFR, without an autopilot, I will sometimes fly the plane
with nudges of trim, nudges or rudder and sometimes lean forward and
back to make minor changes.. But I havent tried steep turns like this yet.
Dave
Old July 8th 04, 02:18 AM
Darrell
Couldn't happen that way. If he rolled in the nose up trim BEFORE he rolled
into the turn using rudder it would have pitched up immediately. But if he
rolled in the nose up trim WHILE the aircraft was entering its bank and
coordinated it perfectly he could do it. But I doubt anyone's perfect and
the whole thing sounds suspect. And no, it's not proper turn entry. But
as a demonstration of trim rather than up elevator to increase back pressure
in a steep turn that is interesting. Using rudder to enter the bank is a
good demonstration, also. Steep turns in most aircraft, however, are
performed not changing elevator/stabilizer trim from the level flight
setting. And rolls into bank are coordinated using aileron/spoiler with
appropriate rudder.
B-58 Hustler History: http://members.cox.net/dschmidt1/
of.
I'm
Roger Long
Old July 8th 04, 03:16 AM
Dudley Henriques
heard of.
rudder
yoke. I'm
entering an
Roger Long
Roger;
If he did this EXACTLY as you indicated, I make it a climbing left turn.
Rolling in the trim even leading the rudder a little bit would cause a
positive pitch immediately, then as the rudder was introduced, it would
have to be very gentle to negate any adverse yaw. It would yaw into the
left side ok if done this way, but it looks like the trim would have
become the dominant factor by that time and a climbing left turn would
be the result.
These "maneuvers" were popular back in the early days of private pilot
instrument introduction. There were several "save your life" maneuvers
that were bantered around at that time; supposedly to save your butt if
you got caught over the top, or inadvertently flew yourself into some
bad weather. Frankly, I didn't like any of it then, and I still wouldn't
advocate using it.
This little ditty using the trim would be VERY difficult to get done in
actual instrument conditions; this of course depending on the airplane
being used. But my money would go on the trim and rudder use not being
applied in the exact sequence required to produce a stable level turn.
I'd bet the house on the trim being early and raising the nose on
someone trying this in actual conditions, then the rudder yawing into a
left climbing turn, which could REALLY get somebody who 1. didn't know
enough not to be there to begin with....and 2. not know enough to make a
simple normal instrument coordinated turn....into REAL trouble FAST!!!!
The real answer to these little catch all ditties is for pilots to learn
right from the gitgo, the right way to do things normally, and be able
to control their airplane without all these "gadget turns"...then, have
enough common sense to stay out of these bad weather situations where
they need to use that control. :-))
Dudley
Old July 8th 04, 03:39 AM
BTIZ
I've done it with a Piper 180... it's no big deal really.. just be ready for
the "Bump", when you come around the 360 and hit your own prop wash..
BT
of.
I'm
Roger Long
Old July 8th 04, 06:26 AM
Jack
Which probably means you have descended slightly rather than making a
perfectly level turn, but it's good enough for .gov work.
Jack
Elite and CH Flight Sim Yoke - USB tscottme Instrument Flight Rules 3 December 22nd 10 12:34 AM
Why is a standard hold right turns? Roy Smith Instrument Flight Rules 51 August 28th 04 07:09 PM
Beech dual yoke w/rams horns/color preference Dan Karshin Aviation Marketplace 1 March 28th 04 06:04 PM
CH Product Yoke with IP Trainer 6.5 Sanjay Kumar Instrument Flight Rules 2 October 10th 03 08:47 AM
Can F-15s making 9G turns with payload? Paul J. Adam Military Aviation 114 September 27th 03 06:47 AM
