Replacing the mixture control with a pre-charger
Old July 14th 04, 11:01 AM
DeltaDeltaDelta
Default Replacing the mixture control with a pre-charger
A couple of days ago, I downloaded a Diamond HK36 motor glider for Flight
Simulator. Upon closer inspection of it, I found out that it has no mixture
control lever, but it has a low-power turbocharger. So it got me wondering:
1.) does the real aircraft have that and 2.) can it be possible that, since
a motor glider is not required to climb very high, this system would be
installed to make operations simpler? It would make sense, since the charger
would supply the engine with near-sea-level air density up to the altitude
from which it could begin the glide, so mixture control would be
unnecessary. If this does exist on real-world aircraft, what are the
advantages and disadvantages of that system? And does this system simplify
or aid in any way in starting the engine in-flight?
Triple Delta
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 05:30 PM
Shakedown: Friction Lock for Old 172 Mixture Control: $60 jls Home Built 2 January 30th 04 02:05 AM
Tactical Air Control Party Airmen Help Ground Forces Otis Willie Military Aviation 0 January 22nd 04 03:20 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
