C182S - CHT's and EGT's
Old September 16th 04, 04:47 PM
john smith
Default C182S - CHT's and EGT's
Any flying a C182S with all six cylinders being monitored, what are you
seeing for CHT's EGT's(corresponding power settings and fuel flows)?
At 65% power 23" MP and 2300 RPM I am seeing 1400 deg F CHT's and 410
deg F CHT's with fuel flows lean of peak about 12-13 gph.
Old September 16th 04, 04:57 PM
Jim Weir
Can't speak to the S model, only the A model. Normal EGT is 1475 and CHT runs
about a needle below 350.
john smith
-Any flying a C182S with all six cylinders being monitored, what are you
-seeing for CHT's EGT's(corresponding power settings and fuel flows)?
-At 65% power 23" MP and 2300 RPM I am seeing 1400 deg F CHT's and 410
-deg F CHT's with fuel flows lean of peak about 12-13 gph.
http://www.rst-engr.com
Old September 16th 04, 08:34 PM
gwengler
john smith wrote in message .. .
Whoa! Lycoming engines are recommended to be run at CHTs of 400 deg F
or below. And Lycoming does not recommend running the engine lean of
peak. To quote from one of their publications:
"The fact is that the technique of operating lean of peak and power
recovery was discontinued due to the resulting increase in service
issues. Burned pistons, valves, ruined rod and main bearings were
traced to the inability of pilots to utilize this technique with the
instrumentation and distractions found in the typical general aviation
aircraft. If Lycoming felt that this was indeed an efficient and
reliable method of operation, you can be sure that it would be in our
recommended procedures."
Gerd
ATPL, T182T
Old September 16th 04, 10:01 PM
Dan Luke
Translation: "There's nothing really wrong with it, but Lycoming considers
most pilots too ignorant and careless to do it properly."
(Not that I necessarily disagree with this.)
Dan
C172RG at BFM
Old September 16th 04, 10:02 PM
Newps
That's way too hot on your CHT's. On my 67 I have a hard time getting
over about 325 on the CHT.
Old September 16th 04, 10:28 PM
Corky Scott
Not positive about this but it does not sound like you actually got to
the lean of peak setting. If you had, the cylinderhead temps would
have been MUCH lower. The old Pratt and Whitney charts indicate that
aluminum begins to loose strength at 400 degrees.
Corky Scott
Old September 17th 04, 03:42 AM
john smith
If I go a few degrees lower, the engine sputters.
Corky Scott
Old September 17th 04, 04:16 AM
Morgans
"john smith" wrote in message
Do you have GAMI injectors? If not, "Thou shalt not run LOP!"
Follow engine manufacture's instructions, if you can't get down to their Max
CHT's.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.762 / Virus Database: 510 - Release Date: 9/13/2004
Old September 17th 04, 02:30 PM
Corky Scott
On Thu, 16 Sep 2004 22:16:31 -0400, "Morgans"
CHT's.
I strongly agree. If you cannot reach lean of peak without having the
engine run rough, then don't.
Because of your particular fuel/air distribution situation, it appears
you will have to run rich of peak at all times in order to achieve
smooth running. I suggest you lean to peak and then richen for the
POH suggested temps and just accept the higher fuel burn than running
lean of peak offers. It's not good to be running CHT's higher than
400F. It's not great to be running even that high, you should try to
keep them under 400F.
This is all spelled out in minute detail in John Deakin's AVweb column
"Mixture Magic". See below.
http://www.avweb.com/news/columns/182084-1.html
Corky Scott
Old September 17th 04, 02:37 PM
john smith
Yes. CHT's are within 10 deg F over the six cylinders, with #4 being the
hottest. EGT's, I don't remember, but they also have a small spread.
CHT's.
Mogas: what happens to EGTs? Stu Gotts Owning 21 March 10th 04 04:21 PM
