Class C = Class B in Canada?
Old September 18th 04, 06:57 PM
Clyde Torres
Default Class C = Class B in Canada?
Does anyone in this forum know if class C in Canada is equivalent to class B
in the USA? I have been told that the USA does not follow ICAO conventions
and is therefore wrong? Can anyone here credit or discredit this statement?
Thanks.
Clyde Torres
Old September 20th 04, 07:06 PM
Brian Burger
In practice, Canadian C more or less equals US B; they're both used for
terminal areas around major airports. Canadian B is (AFAIK) only used from
12,500ft-17999ft.
(I have heard that Toronto/Pearson uses actual Class B down to the surface
for their control zone, but I live on the far side of the country and
haven't bothered confirming this. Anyone know if it's done this way?)
Canada doesn't follow ICAO conventions all the time either - our "Class F"
Restricted/Advisory airspace isn't what the ICAO means by Class F.
Countries don't *have* to follow all the ICAO conventions - they can pick
and choose, and then register their differences w/ the ICAO.
Brian.
www.warbard.ca/avgas/
Old September 20th 04, 08:22 PM
Icebound
"Brian Burger" wrote in message
ia.tc.ca...
class B
conventions
statement?
12,500ft-17999ft.
No, Toronto/Pearson is a standard upside-down cake, considered class C,
topped at 12.5.
Class B in Canada is only that bit from 12.5 to 18.0 along airways and other
geographical areas where it is considered "controlled" and hence Class B...
Old September 20th 04, 09:18 PM
Paul Tomblin
ria.tc.ca...
topped at 12.5.
I thought the center core of the class C is class F because it requires an
arrival reservation?
Revenge is an integral part of forgiving and forgetting.
-- The BOFH
Old September 20th 04, 10:42 PM
David Brooks
ia.tc.ca...
class B
conventions
statement?
12,500ft-17999ft.
I think the ICAO class definitions are only about how the airspaces are
controlled and what services must be offered. They don't tell you how to lay
out the airspaces. Thus Class A is "IFR only", but it's the decision of the
US to put it up above 18,000ft (and to put the transition altitude at the
same level), while other countries have A to the surface around major
airports. The US didn't implement Class F because it doesn't have a control
regime that corresponds with the international definition of F.
Someone correct me if there's an ICAO document also talking about airspace
design.
-- David Brooks
Old September 21st 04, 03:13 AM
Icebound
ria.tc.ca...
surface
topped at 12.5.
The Terminal Chart calls it C.
I don't believe a Reservation requirement would make a class F, anyway. My
reading is that class F is a different purpose totally... Restriced: where
non-participatories are not allowed in, ever... or Advisory: where as
non-participatory you "should" avoid, but you could feasibly still enter at
your own risk...
Neither of those apply to a public airport.
Trip Report - Canada (long) Andrew Sarangan Piloting 8 August 26th 04 04:34 AM
Overlapping class C & D Andrew Sarangan Piloting 14 May 6th 04 05:08 AM
French block airlift of British troops to Basra Michael Petukhov Military Aviation 202 October 24th 03 07:48 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
