WARNING! This post does not contain any political diatribe, personal
castigations, or off-topics musings. The weather over the north end of California's share of the Mojave Desert was once again in the severe clear category. A Mooney departed to the south from Inyokern Airport (IYK) just as I pulled through the security gate by the hangars. Gentle breezes swung the weathervane to and fro. If there were any thermals burping off the pavement, I couldn't tell. The ridgeline of the Sierra was stark against the blue sky blotted by vague hints of cloud vapor 30 or 40 miles to the north. A high pressure mass had settled in and the atmosphere was flat and stable. I preflighted the rental C-150G in its hangar and tucked my stuff into little nooks and crannies. The owner had recently clamped a Garmin-196 to the yoke and I spent some time poking buttons on a totally unfamiliar gadget. Maybe 45 minutes after I pulled through the gate, I pulled on the starter handle -- nothing happened. Ah, yes, master switch ON. The prop turned twice as many rotations as I remembered it usually did. Ah, yes, mag switch ON. Three blades and the little engine that can, was. The devil is in the details. I sat there and let the Hobbs spin while I reread the checklist, again. I know I had read it before I tried the first start. Hrumph! On my side of the hold short line, I did the pre-takeoff list twice just to punish myself. I did a traffic call for takeoff, ess-turned and checked the pattern for traffic, rolled out to the center line and pushed the throttle to the firewall. I need to back up and mention that I hadn't flown the 150 for several months. I'd been flying 172SPs out of the Edward AFB Aeroclub. I was acutely aware of the confines of the cabin already. What I totally forgot was the huge difference between the 180hp, fuel injected, psuedo rocket engines in the 172SP and the little bitty thing on the front of the 150G that was struggling to drag me forward. I'd done a density altitude calc and knew about where I was supposed to be airborne before the intersection of runway 02-20. Airspeed indicator crept up to 40MPH(not knots here), then 45. At the intersection I'd have another 7,000 feet of runway in front of me. There's 50, gentle tug back on the yoke and the nose raised a few inches. At 55, the airplane flew away from the ground. Waiting, waiting, still flying, I crossed the intersection at 60MPH and 100 feet up. I need to accelerate to at least 70 to start a climb. At 200 feet, I was at 75MPH and climbing at about 200 FPM, then 300. Beyond the runnway and 500 feet up, I did a 90left 45right to clear the pattern and made a sweeping climbing turn to head east. Joshua Approach cleared me unrestricted through R-2506, the low approach corridor leading to the Naval Air Warfare Center at China Lake and gave me a 5000 or above for the main SUA of R-2505. I wanted lower -- 5K is about double the altitude of my house which is about 1/2 miles inside the boundary. I'd wanted to so some pictures. Not approved. During the week, I could probably have talked China Control (they own the airspace during normal working hours) into letting me go lower. I headed back west and then south. No place to go in particular. Just remember how to fly the 150. Flight Following reports from Joshua were about 20 minutes apart and only one dealt with 33X (me), so I turned on the Garmin-196 to play with it. I had to change from my sunglasses to regular glasses to read the display. I'd read there is some control over backlighting and contrast, but I didn't have the book with me and couldn't find it intuitively. Basic GPS operation was, on the other hand, pretty intuitive to me. The last person that flew had it set for up is north. I prefer the little plane thingy to point up and have the track line up with it. That I couldn't intuit, either. I played with the psuedo-panel page for a while. I suppose if you had a panel failure on the airplane, you could use that feature, but I didn't get comfortable with the update lag in the brief time I flew with it. CalCity airport was busy with meat-missles so I stayed well to the west. I've proably offended a number of the residents of this newsgroup with that. So flame me. Skydiving is not on my list of things to do, ever. With the exception of five minutes crossing over Red Rock Canyon both ways, the flight was delightfully smooth. Over the canyon the air was four stages below mild turbulence -- maybe a one on the ten-scale. According to the Garmin-196, I had no crosswind drift with the HI and the GPS heading on the same number. On the way home I had not heard a single peep on 122.8 of any traffic at IYK so I decided to try something I'd never done before. There in front of me, ten miles away, I was lined up exactly with runway 02. I keyed the mike and announced my intentions to do a straight-in approach. Maybe I'll try it again someday -- after I look at the geometry, and what altitudes you should have at what distances. But this time I was way too high and way too fast. When It was apparent I could NOT make that landing, I sidestepped into a right downwind for 20 at pattern altitude and made an unevenful landing. It may have been easier if the two-box VASI had been in operation, but all I had was my personal visual perception and it had no history. Oh, yeah, I did go through the landing check list and did use the carb heat. It was a good day to fly over the Mojave, this day. Casey Wilson Freelance Writer and Photographer |
| Thread Tools | |
| Display Modes | |
| Very Nice | Fil330 | General Aviation | 0 | June 10th 04 09:01 PM |
| FA: Raytheon Thermal Imaging Camera - Very Nice! | Michael J. | Military Aviation | 0 | April 22nd 04 12:23 AM |
| Nice Surprize During Pre Flight, And A Few Odd Questions | MRQB | Owning | 12 | March 25th 04 12:26 AM |
| Nice Song on NPR | G.R. Patterson III | Piloting | 1 | January 27th 04 04:47 AM |
| How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 01:05 AM |
