report a near-collision to FBO owner?
Old January 4th 05, 09:03 PM
gatt
Default report a near-collision to FBO owner?
While preflighting the Arrow yesterday afternoon I watched a C172 pull up
through the tiedown T right next to me. Not sure why he didn't stop right
at the chains. Instead, he pulled ahead and stopped.
As he was beginning to push the airplane back, the other FBO C172 darted in
from behind and took the first guy's parking spot like it was a friggin'
shopping mall parking lot at Christmas.
So, for a second, while I watched, one pilot was pushing his airplane back,
toward the other, who was moving up on his tail at greater than walking
speek with his engine running. When his prop stopped about 2 feet from the
first airplane's tail. To the immediate right of the airplanes was the
other FBO tiedown spot, which was perfect empty, because that's where the
2nd aircraft was normally tied down.
The pilot of the first plane decided to walk off his anger. The pilot of
the second acted absolutely oblivious, as if it was the other guy's fault
for almost pushing his airplane back into the guy's prop. He just shrugged
the whole incident off and went about his business. No harm, no foul.
Another pilot came along a bit later and helped the first pilot drag the
airplane to the empty spot right next to them.
Here's the catch: The FBO owner explicitly forbids taxiing in from the back
because of clearance issues. Specifically, because a newly-minted private
pilot had tried to hotrod the 172 into the tiedown a couple of months ago
and banged wings with the other 172. The damage was between spars, so the
repair was $900 and some Bondo. Three weeks ago his instructor was
terminated for doing the SAME THING, except, fortunately, he didn't hit the
wing. Made such a racket jockeying the brakes and the throttle between
airplanes, though, that people complained.
It turns out the pilot who had the collision had done nearly the same thing
returning from his checkride...except, fortunately, the other plane was a
transient Bonanza. DURING THIS GUY'S CHECKRIDE, his wingtip passed right
over the Bonanza's, and he PASSED.
So in the last couple of months I've seen four people not just break the FBO
policy, but taxi like idiots all but parallel parking their airplanes around
others, and near prop-strike that would have showered me with debris, and
both of the FBO Cessnas scratched or dented by a guy who nearly collided
with a Bonanza while passing his checkride.
WTF is going on here?! And how can you even pass a checkride if your wing
passes over the wing of a parked aircraft?
The fellow who runs the FBO is a retired cop, mayor and career Marine. He's
gonna blow a gasket when he hears about it, but I believe it's my duty to
report what I saw almost happen to his airplanes. Thoughts?
-c
Old January 4th 05, 09:23 PM
NW_PILOT
"gatt" wrote in message
in
back,
back
g
FBO
around
He's
-c
Gorge Winds ramp is large enough it would take a very unsafe pilot to bang
something up or even hit another airplane. I would contact the pilot and
have a discussion with them about it first remind them of the rules and tell
them that if you see it happen again it will be brought to Gorge Winds
attention. If the pilot don't understand or is unresponsive, rude then yes
bring it to attention Gorge Winds because I would not want that fellow
taxiing near my airplane and if they keep damaging the aircraft the rates
you will pay will go up.
Old January 4th 05, 10:36 PM
gatt
"NW_PILOT" wrote in message news:X7Kdnae5mqN-
Plus, every FBO airplane there has a spot reserved for it. The guy could
have simply pulled into the one from which he took the airplane instead of
taking the spot the other fellow was already pushing his plane into.
Crazy. The owner's on vacation but since my first post I've learned that at
least two of the instructors saw it happen, so I think there's going to be
some attention given to the incident anyhow.
-c
Old January 4th 05, 11:05 PM
gatt wrote:
snip
wing
I don't think that is specifically against any rules. Often times
while parking I'll manuever my (low) wing underneath the wing of a
neighboring Cessna. Of course, I'm just not tearing willy-nilly into a
parking space without regard to other airplanes or people. I do it
slowly and carefully.
That said, it sounds like the FBO has instituted these rules for a
good reason (tight parking, foot traffic). If people are regularly
breaking the rule and causing the problems you described, I'd certainly
bring it up with the FBO management. Perhaps they need to emphasize
the rule a bit more and spell out some penalties. It sounds like they
might not have spread the word in a strong enough manner.
Old January 4th 05, 11:13 PM
Nathan Young
On Tue, 4 Jan 2005 12:03:38 -0800, "gatt"
snip
Rather than bust the pilots (although it sounds like the 2nd C172
pilot was an idiot) - can you address the root of the problem so that
it doesn't happen anymore in the future?
I am having a difficult time visualizing the ramp setup... But, would
it be possible to paint diagonal yellow stripes behind the tiedown to
indicate that the area is not to be traversed.
For an aviation sense of humor, how about a hold short line behind the
tiedown?
Having said this, people are lazy, and will always cut corners. And
it is hard to legislate against stupidity. Last summer, we had a
transient taxi off the parallel taxiway, across the grass to pull
directly into a tiedown on the edge of the ramp. The tiedown is next
to a fuel farm and there are concrete posts to protect/prevent against
wingtips hitting the pump. The transient Cessna hit the concrete
post, and the wing was badly damaged. The pilot ranted at the FBO
staff and promised to sue them for damages because the FBO told him
(via radio) to park in that spot. Of course, the FBO never told him
to skip the taxiway to the ramp and cut across the grass...
-Nathan
Old January 4th 05, 11:21 PM
Dave Stadt
So what's the big deal of a high wing passing over a low wing?
thing
Old January 4th 05, 11:27 PM
BTIZ
bang
at
-c
If the instructors are in the employ of the FBO.. and they don't say
something... around here they'd be fired for not doing their job.
Personally, if you have a good relationship with the FBO.. have a closed
door... I'm nervous about the operations around here because.. I could get
roped into the next guys accident if I was preflighting or parking and he
hit me... and end it with... It's something I think you ought to know.. I
enjoy flying your planes... but these guys out here don't follow your rules
and I'm not sure they don't do the same in the air and may overstress
something and I get a broke plane and don't know it.
but that's jsut my 2c
BT
Old January 5th 05, 12:35 AM
Bob Gardner
I'll buy all of your argument except the rant about high wing/low wing. Done
it many times without swapping paint. Can't imagine a DE getting upset about
it.
Bob Gardner
in
back,
back
thing
FBO
around
He's
-c
Old January 5th 05, 02:43 AM
nobody
OK, how about something like this...
Tell the owner about the incident you saw, express your concern about damage
to aircraft and safety in general. If he demands to know the identity of the
pilots involved, tell him and let him handle it. Otherwise, suggest a
bulletin board posting or better yet a letter sent to all club
members/renters with something like 'in the past few weeks...several safety
and courtesy issues have arisen...', spell out some rules for the club/FBO
regarding taxiing and parking, and end it with '..any pilot reported
violating these safety rules will have membership/renter status revoked
immediately'.
Basically, ship up or ship out.
Old January 5th 05, 02:45 AM
Colin W Kingsbury
Ditto that.
"Bob Gardner" wrote in message
Done
about
it.
Bob Gardner
molding plexiglas websites? [email protected] Owning 44 February 17th 05 10:33 PM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 13th 03 12:01 AM
Report blames pilots in crash of two Navy jets Otis Willie Naval Aviation 0 September 26th 03 02:27 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
Senator asks Navy for report on pilot Otis Willie Naval Aviation 0 July 17th 03 11:08 PM
