Do all aircraft...
Old January 7th 05, 01:57 PM
Ramapriya
Default Do all aircraft...
.... necessarily have Autopilot?
Ramapriya
Old January 7th 05, 02:17 PM
Gig Giacona
No
"Ramapriya" wrote in message
Ramapriya
Old January 7th 05, 03:20 PM
Gene Seibel
Never flew one that did.
Gene Seibel
Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html
Because I fly, I envy no one.
Old January 7th 05, 03:32 PM
Ramapriya
Wow, but isn't that a pain in, say, a 3-hour flight? To not being able
to let go of the control column and stretch the legs can be tiresome,
I'd imagine.
And what if you've to go to the loo?
Ramapriya
Gene Seibel
Old January 7th 05, 03:44 PM
C J Campbell
I'd imagine.
Lavatories are located at each end of the flight. There is no room to stand
up or walk around in most small planes. They are even smaller than the
interiors of most compact cars.
Old January 7th 05, 04:00 PM
Thomas Borchert
Ramapriya,
To not being able
I'd imagine.
You can do both. Not for THAT long, but for a minute or so under most
circumstances. Legs you cen move freely for hours.
Thomas Borchert (EDDH)
Old January 7th 05, 07:12 PM
NW_PILOT
Its called an external catheter an if you cannot hold it for 3 hours you may
need to go see a Urologist to see whats wrong.
I'd imagine.
Ramapriya
Gene Seibel
Old January 7th 05, 07:18 PM
able
I'd imagine.
It's not too difficult. In the summer, I usually make a few 8 hr.
flights up north. Two legs of 3.5 to 4 hours. If the plane is
properly trimmed, I can fly with a very light touch on the yoke, or
even using my knee. Leg stretching is easy, as rudder is not usually
required in cruise. The loo situation is solved by careful planning
of fluid intake.
My plane has an autopilot (single axis wing-leveler) that has been
inoperative since I bought the plane over 10 yrs. ago. I haven't seen
the need to spend the money to have it fixed. It's primary value is
amusement. It wants to roll hard right every time it's turned on.
Occasionally, I'll secretly turn it on while another pilot is flying
from the right seat. The look on their faces is priceless :-)
Old January 7th 05, 07:38 PM
Stefan
I'd imagine.
Yes, it's extremely painful, tiresome and boring. I'd strongly advise
against learning to fly. (Make a couple of children instead, much more
fun and not more expensive.)
Stefan
Robert M. Gary
No, there is something else that helps the plane fly straight called
"trim". We trim the plane so that with hands off (and no turb) the
plane flys straight. Its not as good as an autopilot because it will
drift but it allows you to relax your hands.
-Robert
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
