PowerFlarm Butterfly Display not changing range
Old April 28th 14, 07:16 PM posted to rec.aviation.soaring
Default PowerFlarm Butterfly Display not changing range
I'm currently running PF 3.40_6658 and Butterfly display bfd_3_3_2348. When I try to change the display range (rotating knob)the display range remains at 6mi, even if target is within inner circle. The push button works providing target details.
This is the second display I've had in two years!
Any suggestions? (I plan on installing my display in friend glider to see if problem is isolated to my display. His display is working properly).
Old May 1st 14, 05:54 PM posted to rec.aviation.soaring
Andy[_1_]
On Monday, April 28, 2014 10:24:14 AM UTC-7, Luke Szczepaniak wrote:
Rotating the switch changes targets, rotate the knob while pressing down
to switch the scale.
Yes, that's how mine works too. Not intuitive though, particularly if you also have a portable PF.
Andy
Want to talk with Butterfly vario + PowerFlarm people [email protected] Soaring 13 July 8th 13 05:52 PM
PowerFlarm: 2.7 Vertical Range [email protected] Soaring 8 April 10th 13 12:27 AM
PowerFlarm Range Analysis Richard[_9_] Soaring 0 March 25th 13 05:43 PM
PowerFLarm expected range [email protected] Soaring 6 August 30th 12 04:43 PM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 26th 12 12:58 AM
