Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Restoration
Corrosion-proofing internal surfaces of aluminum aircraft
Old November 3rd 04, 03:51 AM
aa
Default Corrosion-proofing internal surfaces of aluminum aircraft
I am in the process of restoring a Cessna 170. It is a major restoration
with many fuselage and wing skin pieces being replaced. How should I treat
the interior surfaces? I initially planned to paint everything with zinc
chromate. But the more I look into this, the more I worry about the
toxicity of the zinc chromate and the lack of effectiveness in terms of
corrosion proofing. I've heard of folks using self-etching primers, wash
primers, epoxy primers, nothing at all, or even spray can enamels.
What would you recommend?
Alex
N170W
Cessna 170B
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 04:36 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 06:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 10:14 AM
