Restoring Expired Registration
Old May 12th 14, 07:32 PM posted to rec.aviation.soaring
LongJourney
Default Restoring Expired Registration
I searched the archives of RAS but didn't find anything on this. If an aircraft owner fails to re-register the registration and the FAA shows it expired on their website, what is required to get the registration restored and has anybody had this experience? How painful was it?
I'm not in this situation, but may be looking at a glider with expired registration.
Jeff
Old May 12th 14, 08:37 PM posted to rec.aviation.soaring
Jeff
The FAA website has guidance on this. If it has been out of register long enough, the number may have been reassigned. This make the job more complicated because a new airworthiness certificate will be needed.
UH
Old May 12th 14, 08:39 PM posted to rec.aviation.soaring
LongJourney
Jeff
UH
I was unable to find any information on restoring the registration other than calling the FSDO.
Jeff
Old May 12th 14, 09:12 PM posted to rec.aviation.soaring
LongJourney
Jeff
UH
Jeff
Okay, I found it in a pdf file on the FAA website.
SUSPENSION OR REVOCATION OF CERTIFICATE.
Noncompliance with Federal Aviation Regulation 47.51 (which requires submission to the FAA of a triennial report on AC Form (8050-73) may result in revocation or suspension of the registration certificate. After an Order of Revocation has been issued, the last registered owner may reregister the aircraft by submission of a new aircraft registration application and $5. A new owner may
register the aircraft by submission of evidence of ownership,application, and $5.
I would still be interested in any personal experiences, e.g., how ling the process took, how much of a headache, etc.
Jeff
Old May 12th 14, 09:21 PM posted to rec.aviation.soaring
Jeff
UH
Jeff
Jeff
If no clinkers it will take 3- 4 weeks. The "standard" target turnaround time in OK city is 15 working days.
If clinkers, it can take months, and many turnaround cycles and I do not over state this.
UH
Old May 12th 14, 09:40 PM posted to rec.aviation.soaring
vontresc
Jeff
UH
Jeff
Jeff
UH
The feds have cleared a lot of the backlog. We screwed up when they first did the registration expiration process, and let our Pawnee expire. We were down for close to 6 weeks, but that was a few years ago when we had an extra lousy spring so it didn't suck that bad.
AFAIK if you are buying a plane with an expired registration, as long as the N-number has not been reassigned, just filing the registration and bill of sale should be enough. IIRC in that case you could technically fly on the pink slip.
Peter
restoring aircraft Dave068 Home Built 4 August 29th 04 01:35 PM
restoring aircraft Dave068 Home Built 1 August 10th 04 03:12 PM
What are you restoring? Anybody. Randy Tait Restoration 5 March 8th 04 07:04 AM
Expired WAC Charts AXA General Aviation 2 December 19th 03 08:56 PM
Restoring bubbles... The Raven Restoration 4 July 7th 03 06:07 PM
