Turbulent Flow Fields / Large Eddy Simulation
Old May 30th 14, 01:28 PM posted to rec.aviation.soaring
Default Turbulent Flow Fields / Large Eddy Simulation
Soaring attracts a remarkably diverse and talented group of people from a variety of technical fields. Maybe you are working in the subject or know someone who is. I would appreciate input in this regard.
Comments: While there is a large body of work regarding mountain wave and subsequent clear air turbulence (primarily because the scale and intensity of these events are large enough to substantially affect common and even large scale aircraft), there is a comparative paucity of detailed work in smaller scale events which are still large enough to scale according to mountain ranges, ridges, etc. A cursory examination reveals that CFD with much definition was not applied until something around the late 1980's. Progress since there does not appear to be rapid.
I have some algorithms I've developed and used to effectively in past research to predict stochastic turbulent fields and which are based on the 5/3 energy spectrum. These can be used for small scale up to medium scale integrations. NREL logarithms developed to aid in wind tunnel research might have enough flexibility to simulate large eddies in the medium to larger scale, but I'm guessing not on mountain scale very accurately.
I don't think that the RASP algorithms provide a high enough degree of resolution, but could be wrong in this regard as I don't know much about their implementation- and I am often wrong.
Once again, any help in this area would be appreciated. So as not to clog this newsgroup, please respond directly to me: gosoba at google dot com
Best Regards,
Gary Osoba
Old May 31st 14, 02:57 AM posted to rec.aviation.soaring
Sarah[_2_]
Hello Gary,
I don't know much of anything about RASP, but the base program is NCAR's WRF. I think you're correct in that resolution will limit it's application to large geographic area LES. Or maybe not. All you need is a really big computer. I do know about big computers .. but again, not much about the theoretical methods you're talking about.
Google "WRF large eddy" for some mesoscale results.
Best,
Sarah Anderson
Best Regards,
Gary Osoba
Eddy Currents [email protected] Piloting 10 December 25th 07 02:19 AM
Druine Turbulent Stealth Pilot Home Built 0 August 30th 04 06:05 PM
CAP232 from Eddy Dussau Rie Janssen Aerobatics 4 July 15th 04 05:18 PM
CAP232 from Eddy Dussau Rie Janssen Aerobatics 0 March 23rd 04 02:06 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 09:35 PM
