FAA says homebuilders have to build the components of their projects off-airport
Old August 7th 14, 04:03 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Larry Dighera
Default FAA says homebuilders have to build the components of their projects off-airport
FAA Says Hangars No Place For Homebuilders
http://www.avweb.com/eletter/archive...t=email#222534
The FAA says most of the work involved in building an airplane is a
"non-aeronautical use" and it has singled out homebuilders in a new proposed
policy statement issued July 22. Policy
https://www.federalregister.gov/articles/2014/07/22/2014-17031/policy-on-the-non-aeronautical-use-of-airport-hangars#h-13
on the Non-Aeronautical Use Of Airport says homebuilders will have to build the
components of their projects elsewhere and can only move to a hangar for final
assembly. Comments are being accepted until Sept. 5 and can be submitted online
citing docket number FAA-2014-0463 http://www.regulations.gov/#!home. The
agency has devoted a separate section in the proposed policy to explaining its
stand. The essence is that the principal role of a hangar is to supply enclosed
storage for aircraft to give ready access to the runway. The FAA's argument is
that bucking rivets on a wing doesn't require a runway so it's not an
aeronautical use. It also says the policy has always been in force. "The FAA is
not proposing any change to existing policy other than to clarify that final
assembly of an aircraft, leading to the completion of the aircraft to a point
where it can be taxied, will be considered an aeronautical use," the proposed
policy says. EAA is aware of the proposed policy and staff are assessing it.
The new policy statement is the result of stepped-up enforcement of the rules
regarding uses of airport hangars. In dozens of audits conducted over the past
two years, the agency has found hangars crammed with just about everything but
airplanes. Household goods, cars, even non-aviation related businesses have
been discovered. The FAA says that because federal funds are used to build and
maintain airports, the use of airport facilities for non-aeronautical uses
amounts to a subsidy for those uses. In some cases the city or county
responsible for the airport was the violator. Auditors found police cars and
other municipal assets tucked safely away in airport hangars. The proposed
policy will also clarify the incidental storage of non-aeronautical items in
hangars, meaning that a couch and a beer fridge will probably be safe from the
feds.
Old August 8th 14, 04:54 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Sylvia Else
Default FAA says homebuilders have to build the components of their projectsoff-airport
feds.
Although of obvious concern to those who are using aircraft hangers to
build their aircraf, the FAA does appear to have a point. Demand for
hanger space for non-Aviation purposes will inevitably push up the cost
of hanger space to those who, because their use is Aviation related,
have no practical alternative.
Sylvia.
Old August 8th 14, 08:01 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Larry Dighera
On Fri, 08 Aug 2014 13:54:17 +1000, Sylvia Else
feds.
Sylvia.
I agree.
As a side note, I've had a $150.00 deposit for a hangar at KSNA for in excess
of ten years. During that time, my position on the list has not advanced.
It would seem, that the FAA mandated fee for a hangar is on the order of
$100.00 per month, and this prompts those that hold a hangar there are induced
to "sublet" their hangars for the going rate of $500.00 per month.
I have also been told by airport officials, that the county is manipulating the
assignment of hangars.
I'm wondering if contacting a FSDO inspector regarding these unfair practices
might be productive. Or is it likely to be another case of, "We're the FAA and
we're not happy until you're unhappy." :-)
Old August 9th 14, 12:46 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Sylvia Else
feds.
Sylvia.
I agree.
That's a nice little earner - $150.00 interest free for ten years -
times however long the list is.
If the county is also running the waiting list, then that looks like fraud.
Sounds like a little (more!) patience would be in order, given that a
policy change appears to be afoot (mind you, I'm not in the USA, and
have no idea how long the FAA takes to implement a change of policy).
Sylvia.
Old August 9th 14, 12:57 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Sylvia Else
Having taken a look at the legislation, I have to say that I'm far from
certain that the FAA really has the power to say how hangars are to be used.
It probably should, given that the government is subsidising them, but
to my mind the legislation doesn't go that deep. The airport plan will
show where the hangars are, and the airport owner will not be able to
pull them down and erect something else, but as long as the hangars are
there, I can't see a constraint that they be used for aviation purposes.
Charging a market rate rent when a hangar is not used for aviation
purposes appears to go against the express words of 49 USC 47107.a(13)(B).
Sylvia.
Old August 15th 14, 01:10 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Morgans[_2_]
"Larry Dighera" wrote in message
proposed
You will probably also find that activities such as building an airplane
would not be allowed by the hangar's insurance policy, unless it has a
sprinkler system. I have personal knowledge of this being the case.
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
Old September 1st 14, 08:27 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Larry Dighera
Default UPDATE: FAA says homebuilders have to build the components of their projects off-airport
Commemorative Air Force Fights Hangar Rule
http://www.avweb.com/eletter/archive...il#222678T he
Commemorative Air Force is asking the FAA to extend the Sept. 5 comment
deadline on a proposed policy on "aeronautical uses" permitted in hangars on
federally funded airports. The CAF says its various museums and shops are all
in violation of the new rules and is asking the FAA to extend the comment
period so the agency can "delve deeper into the unintended consequences" of the
existing document.
feds.
Old September 2nd 14, 04:18 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Bug Dout
There was a great outcry about the FAA's position on the Vans Air Force
forum, as you can imagine. I took the minority view that the rule
clarification to prohibit building (and all non-aviation activities) was
a Good Thing. Of course the VAF'ers don't take well to thinking outside
the narrow box they are in. Somewhere I read a good explanation of the
clarification: if an activity can be done off-airport, it should be done
there. But if the activity can ONLY be done on-airport (like an actively
flying aircraft, or fixing/assembling one so it is flying), then those
should be in hangars.
As someone who was on a waiting list at one airport for years, and
seeing hangars "sub-let" to personal buddies and the wait-list never
advance, and seeing maintenance "projects" drag on for years with no
flying aircraft in hangars, I'm all for this FAA clarification. If
someone wants to build long-term, and doesn't have a garage, there's a
business opportunity: make a few storage units with heat, A/C,
electricity, and a nearby toilet for building projects of any kind. I
think there would be demand for this.
As for the FAA enforcing this, no. It simply gives the airport operator
the means to enforce it. And, it gives the airplane owner with no hangar
access the means to compel the airport operator to enforce this.
Larry Dighera writes:
existing document.
The difference between our decadence and the Russians' is that while
theirs is brutal, ours is apathetic.
~ James Thurber
Old September 4th 14, 10:32 PM posted to rec.aviation.piloting
Default FAA says homebuilders have to build the components of theirprojects off-airport
feds.
Sylvia.
How about using the hangers to quarantine arriving Ebola patients, ala Ellis Island ??
Old September 5th 14, 03:28 AM posted to rec.aviation.piloting
Orval Fairbairn
http://www.avweb.com/eletter/archive...avweb:e2872:21
8609a:&st=email#222534
proposed
https://www.federalregister.gov/arti...031/policy-on-
build the
final
online
The
explaining its
enclosed
argument is
FAA is
final
point
proposed
it.
rules
past
everything but
have
build and
uses
and
proposed
in
from the
feds.
Sylvia.
Island ??
How about putting "jgrove" and others of his ilk in there with them?
S76 Landing Gear Components [email protected] Rotorcraft 0 April 21st 14 10:33 AM
Which Came First, the Santa Monica Airport, Or Those Who Chose To Build Their Homes Adjacent To It? Larry Dighera Piloting 16 May 7th 07 10:34 PM
Crosswind components James L. Freeman Piloting 25 February 29th 04 01:21 AM
FS: Slick ignition components (O-540) David Campbell Aviation Marketplace 0 December 24th 03 02:56 AM
RV Quick Build build times... [email protected] Home Built 2 December 17th 03 03:29 AM
