LXSim
Old September 8th 14, 02:00 AM posted to rec.aviation.soaring
Default LXSim
How do I get the LXNav LXSim program to replay an igc file? LXNav site says it can, but I can't seem to get it to work.
I have placed the igc file in the "flights" file in the LXSim directory and it shows up in the "logbook" on the simulator. Also put it on the SD card, but i can't get it to actually use it to replay the task. I have the proper waypoints and airspace files loaded as well.
Any other tricks in getting the simulator to actually fly a task?
Thanks for any help,
WD
Old September 8th 14, 03:42 AM posted to rec.aviation.soaring
Richard[_9_]
Default LXSim
WD
Start LXSIM
Upper left File Open (select the IGC file and open)
the file loads then select play.
Richard
www.craggyaero.com
Old September 8th 14, 04:29 PM posted to rec.aviation.soaring
Default LXSim
Start LXSIM
Richard
www.craggyaero.com
Thanks Richard. I thought it was probably going to be something simple like this. I was focused on trying to get it to work through the simulator itself.
LXSIM problem Sam Zimmerman Soaring 12 May 31st 14 11:12 PM
