I want to do some flying in Condor this winter and use my Oudie 2 as a PNA (screen PDA in Condor is too small, not configurable.) Can anybody coach me through the cables/Wifi/Bluetooth connection so the Oudie can get position, altitude,speed, etc. from Condor? Computer is a Windows 8 based Lenovo with good graphics, sound etc.
Also, are there any other simple PNA devices running LK8000 or similar that would do the trick? Thanks in advance. Gene Reinecke generein at aol dot com |
On Tuesday, September 23, 2014 7:36:53 PM UTC-4, GeneReinecke wrote:
I want to do some flying in Condor this winter and use my Oudie 2 as a PNA (screen PDA in Condor is too small, not configurable.) Can anybody coach me through the cables/Wifi/Bluetooth connection so the Oudie can get position, altitude,speed, etc. from Condor? Computer is a Windows 8 based Lenovo with good graphics, sound etc. Also, are there any other simple PNA devices running LK8000 or similar that would do the trick? Thanks in advance. Gene Reinecke generein at aol dot com http://www.cumulus-soaring.com/godda...dor-Oudie-1p5m is, I believe, what you will need to use Oudie. |
On 2014-09-23 23:36:53 +0000, GeneReinecke said:
I want to do some flying in Condor this winter and use my Oudie 2 as a PNA (screen PDA in Condor is too small, not configurable.) Can anybody coach me through the cables/Wifi/Bluetooth connection so the Oudie can get position, altitude,speed, etc. from Condor? Computer is a Windows 8 based Lenovo with good graphics, sound etc.Also, are there any other simple PNA devices running LK8000 or similar that would do the trick?Thanks in advance. Gene Reinecke generein at aol dot com You know about the Y key, right? |
Gene,
I bought a cable (4 months ago) from Glidertools.com to connect my Oudie 2 directly to my computer via USB. It was plug and play and works perfectly every time. It is not listed on the website anymore, at least I don't believe it is, however if you email Vladimir (the owner) he will make you one. You can get his email from the website, but if you need it let me know and I will send it to you directly. Hope this helps you out! Josh |
On Wednesday, September 24, 2014 at 12:20:51 PM UTC+2, Josh Fletcher wrote:
Gene, I bought a cable (4 months ago) from Glidertools.com to connect my Oudie 2 directly to my computer via USB. It was plug and play and works perfectly every time. It is not listed on the website anymore, at least I don't believe it is, however if you email Vladimir (the owner) he will make you one. You can get his email from the website, but if you need it let me know and I will send it to you directly. Hope this helps you out! Josh -- Josh Fletcher Hi Josh, I bought a cable from Vladimir but cannot get it to work with my Oudie 2 IGC. I'd be curious to know which model Oudie you have, the OS your are running and the parameters you used to make the link to Condor. Cheers, Rian |
Hi Rian,
I sell a very nice Goddard cable for connecting an Oudie or Oudie 2 to a PC for use with Condor. http://www.cumulus-soaring.com/godda...ndor-Oudie-1p5 However, no cable can be used to send Condor data to an Oudie IGC. The IGC required that the Oudie IGC not be able to receive GPS data from any external source. I mention that in my Oudie comparison table he http://www.cumulus-soaring.com/seeyo...mparison_Table Best Regards, Paul Remde Cumulus Soaring, Inc. ___________________________________________ wrote in message ... On Wednesday, September 24, 2014 at 12:20:51 PM UTC+2, Josh Fletcher wrote: Gene, I bought a cable (4 months ago) from Glidertools.com to connect my Oudie 2 directly to my computer via USB. It was plug and play and works perfectly every time. It is not listed on the website anymore, at least I don't believe it is, however if you email Vladimir (the owner) he will make you one. You can get his email from the website, but if you need it let me know and I will send it to you directly. Hope this helps you out! Josh -- Josh Fletcher Hi Josh, I bought a cable from Vladimir but cannot get it to work with my Oudie 2 IGC. I'd be curious to know which model Oudie you have, the OS your are running and the parameters you used to make the link to Condor. Cheers, Rian |
| Thread Tools | |
| Display Modes | |
| Condor | Evan Ludeman[_4_] | Soaring | 29 | March 13th 13 02:16 AM |
| Condor Thanksgiving and Condor Christmas Contests | [email protected] | Soaring | 0 | October 22nd 12 04:33 PM |
| Condor+SYM/HP310? | sisu1a | Soaring | 5 | November 25th 10 01:20 AM |
| TL-232 Condor for sale | Sten-Anders Fellman | Aviation Marketplace | 0 | September 26th 04 04:29 PM |
