Wind rule of thumb?
Old April 28th 04, 03:16 PM
Bart
Default Wind rule of thumb?
Anybody have a rule of thumb that helps break wind speed/dir into its crosswind
headwind components?
Bart
Old April 28th 04, 09:54 PM
Jim Carriere
"Bart" wrote in message
crosswind
Here are a few... the first two are most important, but put all four
together and it is all you need.
(1)
A 45 degree wind will have crosswind and headwind components of roughly 70
percent.
(2)
30 degrees (off the nose)- the crosswind is 50% and the headwind you can
round up to 90%.
(3)
For less than 30 degrees, the crosswind component versus the angle is close
to linear. In other words, for 15 degrees, 25% is close, 10 degrees, about
15-20%. Also, the headwind component is almost equal to the total wind in
this range, you might as well round it off. You can fudge the number by
subtracting 1 or 2 knots from your headwind if it makes you feel better
Here is an example:
Runway 14, wind 180 at 20 knots. The angle is 180-140=40 degrees. Pretty
close to 45... so use 75% and approximate the crosswind to 14 knots and the
headwind to 14 knots. Using a calculator I get 13 and 15- not bad!
Another example:
Runway 09, wind 070 at 15 knots. I get 20 degrees for the angle, that is
less than 30 degrees, in fact, it is 2/3 of 30, so instead of 50% I will use
2/3 of 50%. So, crosswind? 50% of 15 knots is 8, and 2/3 of that is 6.
Headwind? The angle is so narrow let's say 15 knots. The calculator says 5
knots crosswind and 14 knots headwind. If I had fudged the headwind down by
1 knot then I would have been right on.
And the last rule, which is really just the second and third ones over
again-
(4)
For greater 60 degrees and greater than 60 degrees, just switch the
crosswind and headwind rules with each other for the 30 and less than 30
rules.
(5)
Wait- a bonus rule, useful "on the fly" on cross country to get a crab
angle. 6 degrees equals 10 percent. So if you have a 10 knot crosswind and
you're going 100 knots, crab 6 degrees towards the crosswind. This will
give you a good starting point to correct your ground track from.
Hope this helps
Old April 29th 04, 02:50 PM
Bart
Hey Thanks!
Bart
"Jim Carriere" wrote in message ...
crosswind
(1)
percent.
(2)
round up to 90%.
(3)
Here is an example:
Another example:
again-
(4)
rules.
(5)
Hope this helps
Old April 29th 04, 03:18 PM
Sean Trost
Yeh, Thanks !!
Bart wrote:
Hey Thanks!
Bart
crosswind
(1)
percent.
(2)
round up to 90%.
(3)
Here is an example:
Another example:
again-
(4)
rules.
(5)
Hope this helps
F/A-18 approach speed rule of thumb tscottme Naval Aviation 5 December 7th 04 12:13 AM
Interesting wind experience Roger Long Piloting 3 November 15th 04 06:34 PM
Two non-aviation questions Ramapriya Piloting 12 November 10th 04 01:51 AM
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. Larry Dighera Piloting 0 February 22nd 04 04:58 PM
Hei polish moron also britain is going to breach eu deficit 3% rule AIA Military Aviation 0 October 25th 03 12:06 AM
