Fatalitys in Namabia
Old December 9th 14, 03:43 PM posted to rec.aviation.soaring
glen
Default Fatalitys in Namabia
On Tuesday, December 2, 2014 2:29:42 PM UTC-5, wrote:
Those of you that have flown in NZ probably know these men. They will be missed.http://www.stuff.co.nz/business/indu...a-glider-crash
Does anyone know what happen on this flight to kill two very experienced pilots?
Glen
Old December 10th 14, 07:53 AM posted to rec.aviation.soaring
Surge
We'll have to wait until the investigation results are out but the things that usually kill experienced pilots is the simple stuff such as a stall and spin-in close to the ground.
Hopefully there will be some GPS traces to help investigators figure out what went wrong.
Does the ASH-25 EB28 have the same limitation as the Nimbus 4's where you can exceed VNE or overstress the airframe if you try to recover from a vertical nose down attitude?
Old December 10th 14, 10:19 AM posted to rec.aviation.soaring
krasw
I would like to see a glider which you cannot overstress during vertical nosedive.... SG-38? Space shuttle?
Old December 11th 14, 12:25 PM posted to rec.aviation.soaring
Surge
That's not what I meant.
I meant can the ASH-25 EB28 recover from an accidental spin/wing drop situation (where the nose is pointing at the ground), without exceeding VNE or over stressing the airframe?
Old December 11th 14, 12:48 PM posted to rec.aviation.soaring
Chris Rollings[_2_]
Wouldn't get certification if it couldn't.
vertical
VNE
