Update on CAI flight recorder repairs from CNi (GPS Date problems)
Old December 11th 14, 08:48 PM posted to rec.aviation.soaring
Tango Eight
Default Update on CAI flight recorder repairs from CNi (GPS Date problems)
We've had to change tactics slightly to deal with the Cambridge flight recorder GPS date problems recently discussed here on r.a.s.
Here's the latest:
Cambridge 302 needs a new GPS card to fix this the right way. Simply soldering in a new battery won't get your 302 through Winter storage (which is where *my* 302 vario is right now). Few people will want to remove a vario for the Winter to maintain the GPS date.
This problem will be repaired under our existing CAI 302 flat rate policy: we fix (almost) any 302 and provide a 1 year warranty and fresh barograph calibration for $350.
Cambridge model 10/20/25 flight recorders were always intended to be mounted in an easily removable fashion, so we feel that the battery only fix is better economy for these older units. CNi will replace the GPS date battery, fix your date problem and calibrate the barograph for $125. It will be up to you to maintain the battery by powering up the flight logger for a few hours every 3 months or you will lose the date... there will be a warning/reminder label on your returned unit to this effect.
Gary Kammerer handles all of our CAI service, please find contact info for Gary on our website.
Best regards and Good Soaring in 2015,
Evan Ludeman for ClearNav Instruments
www.ClearNav.net
please join our forum for discussion of all things ClearNav
http://clearnav.net/simplemachinesforum/index.php
Latest update of SeeYou and OLC flight claims causing problems [email protected] Soaring 6 October 30th 14 08:59 PM
New flight recorder - flyWithCE Flight Recorder uros Soaring 12 May 5th 09 09:31 PM
IGC-approval for LXN Colibri recorder - update issued [email protected] Soaring 0 June 20th 05 09:58 PM
Date of effect now 1 October 2004 for revised IGC-approvals for certain legacy types of GNSS flight recorder Ian Strachan Soaring 0 March 15th 04 03:32 PM
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder Ian Strachan Soaring 56 December 2nd 03 09:08 AM
