Best months for soaring near Tucson?
Old December 24th 14, 02:13 AM posted to rec.aviation.soaring
Bret Hess
Default Best months for soaring near Tucson?
When are the best times for XC near Tucson? I grew up in Safford AZ, and I'd like to fly in that area.
Old December 24th 14, 03:22 AM posted to rec.aviation.soaring
Sierra Whiskey
The Tucson Soaring Club Operates all year and is located in Marana, Az.
The Best soaring in Tucson takes place around the May long weekend. Usually we have good soaring from May to October with the exception of the wet days during Monsoon Season. The Monsoons can bring great soaring, but they can also bring some isolated rough weather (Thunderstorms, downdrafts, and rarely hail).
Go to www.TucsonSoaring.org for more information.
Old December 25th 14, 04:43 PM posted to rec.aviation.soaring
Mike the Strike
Although conditions in southern Arizona improve from April onwards and degrade after about the end of October, we have had long cross-country flights in every month of the year. Good soaring from November through March is spotty, however. Moisture is the key to the best flights and the pre-monsoon season from mid May to the end of June often provides the best conditions, with a secondary peak in September and October as the monsoon wanes.
Check out Tucson Soaring Club flights posted on OLC - these will give you a good idea.
Old December 26th 14, 08:35 AM posted to rec.aviation.soaring
Bret Hess
Thanks guys. Ill look at the club info. Good idea using olc to check out the possibilities in the different months. Looks like I can come either end of April or end of June. Or end of August. I'll check out those months.
Tucson Soaring - point of contact wanted John[_27_] Soaring 1 September 15th 11 08:35 PM
D-M AFB, Tucson, AZ Lonnie[_2_] Aviation Photos 12 September 9th 07 05:55 AM
PW-6 arrives at Tucson Soaring Charles Yeates Soaring 0 November 13th 04 01:44 PM
New PW-6U for Tucson Soaring Club Charles Yeates Soaring 0 August 31st 04 10:11 PM
Antares electric self-launcher in this months Soaring Stewart Kissel Soaring 2 June 1st 04 03:14 AM
