O-ring material for DOT-3 fluid
Old January 7th 15, 04:02 AM posted to rec.aviation.soaring
Larry Suter
Default O-ring material for DOT-3 fluid
Just got a new Cleveland caliper assembly for one of our club's G-103's. Grob requires the use of DOT-3 fluid because of the master cylinder. The o-ring in the piston is designed for 5056 fluid. I'm told DOT-3 will call that o-ring to swell. So we need to replace the o-ring.
Does anyone know what common o-ring materials are compatable with DOT-3?
Aircraft Spruce, BTW, doesn't sell DOT-3 compatable o-rings.
Larry
Fluid Power Ohio nimbus Soaring 5 February 24th 09 12:47 PM
Pitts brake fluid Al MacDonald Aerobatics 2 April 25th 05 04:43 AM
BRAKE FLUID Ventus B Soaring 9 October 17th 04 08:25 PM
compass fluid D.A.L Soaring 4 September 20th 03 04:06 PM
Need help with Fluid Mechanics equation Doug Home Built 4 August 16th 03 04:13 AM
