Cobra brake and axle parts offered
Old February 11th 15, 06:46 AM posted to rec.aviation.soaring
Steve Koerner
Default Cobra brake and axle parts offered
My Cobra trailer axle just got replaced due to the fact that it was bent a bit in a freeway collision several months ago. This is a 15M trailer of 2003 vintage (I'm thinking, though, that this same 5-lug Alko brand axle system was used by Cobra over many years). The new axle assembly was quite expensive and came with all new brake drums, cables etc. Accordingly, I was left with a lot of good parts and pieces that someone here might be able to put to good use. The link below has pictures of all of the parts that are available. The brake drums with bearings in place are perfect and the brake shoes look good too. Make me an offer on any parts you might happen to need. Please use reply to author.
For the technically curious, I included a picture of the axle in cut-away showing the rubber torsion spring mechanism (I'd chopped the old axle up to fit it into a rubbish container). Each side is independent as the inner concentric tube is only about a foot long on each side. It seems this inner triangular tube is not axially retained by anything except the tight fit of its rubber support. One of the faults that occurred with my old axle is that the inner tube pulled out by inch or so in the collision. There's a picture of that too.
I also included a picture of the tool I made to remove the dust cap. It's difficult to remove without a tool like this. I'm keeping this tool -- just thought it might of interest to see how such a tool can be readily made on a lathe.
http://www.dropbox.com/sh/5ww9a8wtxl...YH7lhgsma?dl=0
Old February 15th 15, 12:38 AM posted to rec.aviation.soaring
son_of_flubber
On Wednesday, February 11, 2015 at 12:46:12 AM UTC-5, Steve Koerner wrote:
... it was bent a bit in a freeway collision several months ago.
I've been thinking about putting a cheap 'dashcam' or two inside the tail enclosing part of my trailer. One pointed forward and one back through peepholes. Set to record continuous loop automatically whenever the trailer is hooked up and the car is running.
Cobra trailer axle and wheels Phillip LaBerge Soaring 9 January 15th 14 01:11 AM
Cobra trailer axle Pete Dawson Soaring 1 August 15th 09 02:49 AM
ASK 21 in Cobra trailer single or double axle? Karaka Soaring 7 June 19th 09 11:15 PM
Cobra Trailer - U.S. Axle? Mitch Soaring 8 March 2nd 07 10:16 PM
Cobra Brake Parts or Axle WDM Soaring 1 October 11th 04 06:09 AM
