Cobra Trailer: Top's lower front corners distorted
Old February 13th 15, 08:45 PM posted to rec.aviation.soaring
Dave Nadler
Default Cobra Trailer: Top's lower front corners distorted
Hi All - Below is the draft I sent to Spindelberger;
nothing happened since; need to chase it...
Problem is two-fold:
- jack the top back to square
- keep it there
I received instructions starting "remove the top from the trailer"...
Right.
I designed & sketched the kludgery to fix in situ and Alfred
built the parts shown in this document. I thought they were
going to sell repair kits...
http://www.nadler.com/public/Cobra/C...rcement_01.pdf
There are MANY different Cobra tops and the angles and
dimensions of this jack-thing would be different for each.
An alternative scheme would be build an external jack
mechanism, straighten, then install the wee blocks as installed
in the same location on newer trailers. BE CAREFUL!
Hope this helps,
Best Regards, Dave
PS: BE CAREFUL!
PPS: This worked fine on my Antares trailer (20k+ miles
since without further issue).
PPPS: BE CAREFUL!!
Old February 13th 15, 08:57 PM posted to rec.aviation.soaring
Dave Nadler
- keep it there
Right.
Hope this helps,
Best Regards, Dave
PS: BE CAREFUL!
PPPS: BE CAREFUL!!
Alfred also made parts for Eric Greenwell, but Eric hasn't yet
installed them. I'll get photos eventually...
Cobra Trailer front access door .... Ron Gleason Soaring 6 September 9th 14 08:55 PM
Cobra Trailer-Replacing front panel K Soaring 2 January 15th 14 02:25 PM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
Cobra Trailer leak, front end gasket, fix? SF Soaring 1 December 20th 10 07:30 PM
Nat'l Museum USAF-Assorted 11-10-06 - RB-47 lower front left NMUSAF 11-10-06.JPG (1/1) Blue Oval Aviation Photos 0 November 11th 06 02:09 AM
