spare tail dolly wheel assembly
Old February 19th 15, 12:37 AM posted to rec.aviation.soaring
Default spare tail dolly wheel assembly
I was sick and tired of getting flats on my tail dolly and having to fix this past summer. (Also not interested in solid tires due to the hard ride.) I found this and thought others might be interested. It is one heck of a deal for 20 bucks. Includes tire, tube, hub and axle. Works in a pinch so you can just swap and go fly - enabling you to fix the flat on your regular wheel at later time after you land. Just thought I would share and I'am not affiliated with this company.
http://www.monsterscooterparts.com/r...-assembly.html
Darren "U2"
Old February 19th 15, 12:45 AM posted to rec.aviation.soaring
Craig Funston
On Wednesday, February 18, 2015 at 4:37:08 PM UTC-8, wrote:
I was sick and tired of getting flats on my tail dolly and having to fix this past summer. (Also not interested in solid tires due to the hard ride..) I found this and thought others might be interested. It is one heck of a deal for 20 bucks. Includes tire, tube, hub and axle. Works in a pinch so you can just swap and go fly - enabling you to fix the flat on your regular wheel at later time after you land. Just thought I would share and I'am not affiliated with this company.
Darren "U2"
I'll second that. I've bought a couple wheels from Monster Scooter and had good luck with them. Not sure I'd use them for a tailwheel, but for the dolly, they work great.
Craig 7Q
Old February 19th 15, 12:51 AM posted to rec.aviation.soaring
Yes, I am only endorsing for tail dolly only.
Old February 19th 15, 02:29 PM posted to rec.aviation.soaring
Pierre Vav
I 've used it.
Nice to have int he trailer just in case.
but doesn't long too much, and must be replaced by your repaired wheel, at home.
The plastic reem did break after 2 years.
Flat-free glider tail dolly wheel JS Soaring 9 October 12th 14 07:46 AM
Spare wheel/tire Steve Freeman Soaring 0 August 12th 10 11:21 PM
2 wheel tail dolly towing system Philippe Athuil Soaring 2 June 1st 09 04:55 PM
assembly dolly Udo Rumpf Soaring 0 April 29th 05 04:17 PM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
