HI
My Discus 2a manual says the ARM for Pilot & Parachute is ( -17.72 in.) The A&P who did the WT & Balance 10 years ago used ( -15.20 in.) for the ARM. Did he make a mistake? It's a big difference. If you have a D2a can your check your WT & BAL for me. If I could get a copy of your W&B that would be great. Thanks Glen |
On Thursday, February 19, 2015 at 8:06:18 PM UTC-5, wrote:
HI My Discus 2a manual says the ARM for Pilot & Parachute is ( -17.72 in.) The A&P who did the WT & Balance 10 years ago used ( -15.20 in.) for the ARM. Did he make a mistake? It's a big difference. If you have a D2a can your check your WT & BAL for me. If I could get a copy of your W&B that would be great. Thanks Glen See if the manual specifies different arms for light and heavy pilots. UH |
HI My Discus 2a manual says the ARM for Pilot & Parachute is ( -17.72 in.) The A&P who did the WT & Balance 10 years ago used ( -15.20 in.) for the ARM. Did he make a mistake? It's a big difference. If you have a D2a can your check your WT & BAL for me. If I could get a copy of your W&B that would be great. Thanks Glen I don't see that, just a different Arm for a B model. |
CG will vary with seat back position and thickness of parachute. Pilot CG is approximately your belly button. Climb in with chute on and measure the horizontal distance from the wing leading edge to your belly button (use a pumb-bob, then mark edge of canopy rail). If memory serves me, Discus performs best at 92% of allowable range..
:) JJ |
Glen,
Getting ready for the Seniors... huh... I will check my information this evening when I get home. I will e-mail you. Have fun. It's -10 in upstate NY once again. Tim Hanke Discus 2a "H1" On Thursday, February 19, 2015 at 8:06:18 PM UTC-5, wrote: HI My Discus 2a manual says the ARM for Pilot & Parachute is ( -17.72 in.) The A&P who did the WT & Balance 10 years ago used ( -15.20 in.) for the ARM. Did he make a mistake? It's a big difference. If you have a D2a can your check your WT & BAL for me. If I could get a copy of your W&B that would be great. Thanks Glen |
On Thursday, February 19, 2015 at 5:06:18 PM UTC-8, wrote:
HI My Discus 2a manual says the ARM for Pilot & Parachute is ( -17.72 in.) The A&P who did the WT & Balance 10 years ago used ( -15.20 in.) for the ARM. Did he make a mistake? It's a big difference. If you have a D2a can your check your WT & BAL for me. If I could get a copy of your W&B that would be great. Thanks Glen you can back calculate your actual pilot/chute arm if the W&B includes the empty weight as well. SeeG makes this and other calculations for W&B very easy (shameless plug). Visit www.glideplan.com for more info. Matt |
| Thread Tools | |
| Display Modes | |
| Wanted DIscus CS or Discus B | [email protected] | Soaring | 0 | November 14th 08 02:17 PM |
| Discus verus Discus 2, LS8, ASW 28 | Roger | Soaring | 45 | October 31st 06 04:43 PM |
| Discus 3 or Super Discus? | Mirek | Soaring | 1 | June 13th 04 10:28 AM |
| Discus CS and Duo Discus Wing Inspections | Nolaminar | Soaring | 0 | October 24th 03 02:15 AM |
| [LBA] Schempp-Hirth - Discus bT - Discus | Frederic FUCHS | Soaring | 0 | September 17th 03 09:42 AM |
