VFR flight question (MSFS2004)
Old August 25th 03, 09:56 PM
Vic Baron
Default VFR flight question (MSFS2004)
Hi -
I assume you're using the FS2004 FLightPLanner? Just print the
log/flightplan - it should show all the headings and alt's in your plan.
hth,
vgb
"Paul" wrote in message
Hi!
I have a question about flying VFR with a VOR-to-VOR method.
When I ask the simulator to plot the route frm airport A to airport B, it
plots a series of straights Airp A - VOR1 - VOR2 - Airp B.
Now, what I would like to know is the direction for each of the segments!
I
can only eyeball each one: 045 degrees. Or maybe 062 degrees?
I guess, in real life when you plot route yourself on the real map and
adjust for the side wind, you can find the angle by using protractor. How
do I do that in simulator???
Thanks!
Old August 26th 03, 01:12 AM
Brett Holcomb
The MS flightplanner will show you the headings. Just go to that tab in
the planner.
Note, that you can grab a route line with the mouse and drag it to another
location.
Paul wrote:
Hi!
I can only eyeball each one: 045 degrees. Or maybe 062 degrees?
Thanks!
Brett I. Holcomb
Microsoft MVP
AKA Grunt
Remove R777 to email
Old August 28th 03, 09:54 PM
Not Dick Daley
Same way you do it in real life. Use a chart and a plotter.
Hi!
I
Thanks!
Old September 1st 03, 05:03 AM
Ishrat Zahid
Don't quite understand the question. In real world, we use Flight
Computers (manual or
electronic) to punch in the winds aloft at certain altitude. also
factors are the difference
in magnetic and true north, compass error etc.
In simulator it is pretty easy to fly VOR headings:
Assume that the first heading is 124 degrees at frequency 110.6:
1. Tune 110.6 on VOR1 or 2
2. On VOR receiver, set the heading 124 with "TO" indicator
3. Track the VOR
4. Make sure that Compass and heading indicators match
Ishrat
Hi!
I
Thanks!
Flight Planning Software Question Flyin'8 Piloting 10 January 30th 05 05:18 AM
IFR Flight Plan question Snowbird Instrument Flight Rules 5 August 13th 04 01:55 AM
WINGS: When do the clocks start ticking? Andrew Gideon Piloting 6 February 3rd 04 04:01 PM
Flight instructors as Charter Pilots C J Campbell Piloting 6 January 24th 04 08:51 AM
