Wow! Ooops, take #3
Old April 2nd 15, 09:44 PM posted to rec.aviation.soaring
Dave Nadler
Default Wow! Ooops, take #3
Yikes.
http://ad.easa.europa.eu/ad/2015-0052-E
Old April 2nd 15, 10:16 PM posted to rec.aviation.soaring
Andrzej Kobus
On Thursday, April 2, 2015 at 4:44:59 PM UTC-4, Dave Nadler wrote:
Yikes.
Wow, there are many more pure gliders now...
Old April 2nd 15, 11:22 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Yikes.
Hmm. Says it only applies if you have Solo 2350 c and a non foldable propeller. But in the "reason" section, it implies that all Solo 2350 C engine operation is prohibited. Don't know enough on the specific variants of the Solo 2350 to know how many this really impacts.
Also interesting is that you must inspect within 30 days and report your findings. Even if there is no issue to report, it does not remove the restriction from using the engine.
Bad news for all that are affected.
Old April 3rd 15, 01:32 AM posted to rec.aviation.soaring
Bill T
It will only be a matter of time before the U.S. FAA issues an AD based on the AESA AD that will impact gliders in the US.
US owners should heed the cautions and not operate the SOLO engine.
Interesting that the AD specifically identified the previous SOLO service bulletin as not acceptable.
BillT
Old April 3rd 15, 02:10 AM posted to rec.aviation.soaring
Yikes.
The product information website for Solo engines shows that two models of gliders are affected: Ventus CM and the DG1000T. Other gliders with solo motors have differing model numbers.
Old April 3rd 15, 02:14 AM posted to rec.aviation.soaring
Looking at the Solo website http://aircraft.solo-online.com/index.php it looks like the c model is very different in that it shows a belt drive while the straight 2350 shows a direct drive. It appears that the AD is only for the C model.
DVM
Old April 3rd 15, 03:42 AM posted to rec.aviation.soaring
God doesn't like motors on sailplanes.......
Old April 3rd 15, 08:46 AM posted to rec.aviation.soaring
Tango Whisky
It affects ONLY 2350C engines with non-foldable propellor. That's DG1000T in the first place (which caused the AD) and probably J'S. S-H is not concerned (and I'll use it on my Ventus cM).
Old April 3rd 15, 01:49 PM posted to rec.aviation.soaring
Dave Walsh
I think it says more about the technical competence of the
engine designers; maybe God doesn't like them either?
Old April 3rd 15, 01:52 PM posted to rec.aviation.soaring
John Galloway[_1_]
DG1000T
Also the turbo Antares - or at least the prototype according to this:
https://www.youtube.com/watch?v=-mxwvd-ps2A
Ooops... Zomby Woof[_3_] Aviation Photos 0 April 21st 09 04:36 AM
ooopS! my Bdadd Bertie the Bunyip[_2_] Piloting 4 March 29th 07 10:40 PM
Ooops ... incident at Santa Fe A. Sinan Unur Piloting 18 November 10th 06 01:44 AM
Derby weekend ooops Jack Harkin Soaring 0 June 22nd 06 05:44 PM
Ooops - Correction Bill Denton Piloting 0 August 9th 04 01:53 PM
