I have searched RAS for this topic and could not find specific answers so ...
The local club here in Northern Utah has acquired a new Grob Twin Astir with a Terra TX720 radio installed. The radio is working but the On/Off and volume switch has flat spots and we would like to replace it. Does anyone have the schematics for this radio? Or does anyone know the exact switch that is needed (no markings on the existing switch). Thanks in advance Ron Gleason |
On Tuesday, April 14, 2015 at 11:57:09 AM UTC-4, Ron Gleason wrote:
I have searched RAS for this topic and could not find specific answers so ... The local club here in Northern Utah has acquired a new Grob Twin Astir with a Terra TX720 radio installed. The radio is working but the On/Off and volume switch has flat spots and we would like to replace it. Does anyone have the schematics for this radio? Or does anyone know the exact switch that is needed (no markings on the existing switch). Thanks in advance Ron Gleason Redo your search, but use "tx-720" instead. There are quite a few threads that will pop up. IIRC, Gary Kemp had info on the radio, but it's an older thread. |
Search
http://www.esscoaircraft.com Essco website shows they have a paper or downloadable manual in stock for $30. A good investment if you plan to keep this older radio. |
Thanks Burt. We will see what the club wants to do.
On Wednesday, April 15, 2015 at 9:52:17 AM UTC-7, Ron Gleason wrote:
Thanks Burt. We will see what the club wants to do. If it's a simple switch + potentiometer you may be able to measure resistance at several points and find a replacement at Mouser or somewhere like that. If it's just a dirty pot, you may be able to use some cleaner on it and get a few more years out of the existing one. Good luck, Craig |
On Wednesday, 15 April 2015 11:28:22 UTC-6, Craig Funston wrote:
On Wednesday, April 15, 2015 at 9:52:17 AM UTC-7, Ron Gleason wrote: Thanks Burt. We will see what the club wants to do. If it's a simple switch + potentiometer you may be able to measure resistance at several points and find a replacement at Mouser or somewhere like that. If it's just a dirty pot, you may be able to use some cleaner on it and get a few more years out of the existing one. Good luck, Craig Thanks Craig. We have some measurements but the number appear high (I am not a electronic guy) and were hoping to get actual specs before we looked around for a replacement. |
| Thread Tools | |
| Display Modes | |
| Telex ANR schematic | Roger[_6_] | Owning | 1 | September 11th 12 05:04 AM |
| Narco COM 11A schematic | Jstar | Owning | 1 | August 1st 12 03:22 PM |
| Need Schematic for OLD Telex ANR | Roger[_6_] | Home Built | 2 | April 9th 11 11:47 AM |
| NEW Terra TRT 250 and Terra AT 3000 altitude digitizer - $500 | grafxman | Aviation Marketplace | 1 | December 29th 08 07:39 PM |
| FS Terra TX720 | Soaring | 0 | February 12th 04 02:13 AM | |
