Changing from VFR to IFR
Old October 16th 03, 08:50 PM
hawk_spring
Default Changing from VFR to IFR
Is there a way to switch control from VFR to IFR? An example would be I'm on a long cross country trip and suddenly run in instrument meteorological conditions and still wish to continue on to my destination but with IFR ATC control.
Old October 16th 03, 09:49 PM
Bill
2004? Select flight planner from the menu and open an IFR plan and it should
work. I have not actually tried but others have and it seems to work ok.
Only thing I think you have to pay attention to is how you exit the screen
so it doesnt put you back at your starting point. Experiment with it
Bill
"hawk_spring" wrote in message
m...
control.
Old October 16th 03, 10:01 PM
Dashii
One of your choices in the ATC window is "Create or open an IFR flight plan".
Dashii
"hawk_spring" wrote in message m...
Old October 18th 03, 05:32 AM
hawk_spring
No, I'm using 2002
"Bill" wrote in message
should
Bill
m...
ATC
control.
Old October 18th 03, 05:34 AM
hawk_spring
Doing that puts you back at your starting airport at beginning of the flight. I'd like to do it in flight.
"Dashii" wrote in message ...
Dashii
Old October 18th 03, 08:16 AM
Bill
dont think it works in 2002.
m...
No, I'm using 2002
should
screen
Bill
m...
I'm
meteorological
ATC
control.
Old October 18th 03, 10:41 PM
Paul Riley
m...
No it does not, IF you pay attention and say NO when the flight planner asks
you if you want to be repositioned to the starting airport.
AND, this change of flight plan is only possible in FS2004 (FS9), NOT in
FS2002.
Paul
plan".
Dashii
m...
Changing course to do sightseeing - practical (with clearance) when IFR? Mitchell Gossman Instrument Flight Rules 6 July 9th 04 08:38 AM
GAO: Tactical Aircraft: Changing Conditions Drive Need for New F/A-22 Business Case" Mike Military Aviation 76 March 30th 04 08:44 AM
Changing *BIG* Aircraft Tires [Was Coalition casualties forseptember] Stephen Harding Military Aviation 9 October 5th 03 07:42 PM
Changing Magnetos? smf Home Built 2 September 1st 03 02:48 AM
changing names Idrmitch2 Simulators 0 August 8th 03 04:26 AM
