alternative to iGlide for iPhone (6 plus)
Old May 13th 15, 03:08 PM posted to rec.aviation.soaring
Bob Pasker
Default alternative to iGlide for iPhone (6 plus)
I have been using iGlide now for about 20 flights, and I really don't like it very much. It is riddled with bugs (which I have duly reported to Butterfly only to hear "yes, we're aware of that"), the user experience is terrible (and I speak as someone who has worked in user interaction and user experience for years), and the documentation is woefully out of date (last updated 2/2013) and incomplete. So I have wasted $33.
Are there other apps that people recommend for IoS?
thanks, bob
Old May 13th 15, 04:54 PM posted to rec.aviation.soaring
waremark
thanks, bob
Cannot recommend or otherwise, but the main choice for iOs apart from iGlide is Winpilot. Like many others, I used Winpilot for many years on iPaqs and they did a great job. The iOs version is completely different, and I cannot say whether or not it is better than iGlide.
Old May 13th 15, 04:59 PM posted to rec.aviation.soaring
glidergeek
What bugs are you seeing?
jfitch
thanks, bob
Just goes to show that there are many different tastes in the world. I am curious though, you say it is "riddled with bugs" - what have you run into as examples? I am aware only of a couple of fairly obscure ones and have flown with it for many hours.
Winpilot for iOS has promise, but it does not work very well on the 6+ and the up time before a hard crash seems to be only a few minutes.
Old May 13th 15, 05:49 PM posted to rec.aviation.soaring
Sean Fidler
Funny. I find iGlide to be excellent (particularly the UI) and have found very few bugs (both were addresses within days for me) after using it extensively for over 2 years (so far) in numerous contests and cross country flights and in many environments (mountains, flatlands, complex airspace). In my experience, some people just do not get iOS fundementals. Could this, perhaps, be the case for you? What did you not like?
I also have extensive UI design background. I find the iGlide UI to be far superior to any other small portable device soaring software including XC Soar. It requires far less steps to do the majority of critical ot common functions and most pilots I have spoken with find it intuitive and simple to use. This is just my opinion of course.
I have extensive experience with WinPilot, Strepla, SeeYou (Oudie 1 and 2) and XC Soar as well on multiple devices.
I am a member of a firm which primarily consults (and also helps develop) custom mobile applications (typically financial services). UI differentiators (IP, etc) is usually a critical topic.
Please list here (since you flamed it so sharply) all the bugs you found with iGlide, especially the ones the developer acknowledged as "known" bugs. Since you bought the $39 version of iGlide, clearly you have no experience with tasking, etc., correct?
If you want to to talk about terrible UI, I give you SeeYou mobile. Would you not agree?
Then again, UI is a fairly subjective subject and a matter of personal preference.
Can you provide an example of soaring UI's that you approve of?
Thanks!
Old May 13th 15, 06:52 PM posted to rec.aviation.soaring
jfitch
Please list here (since you flamed it so sharply) all the bugs you found with iGlide, especially the ones the developer acknowledged as "known" bugs.. Since you bought the $39 version of iGlide, clearly you have no experience with tasking, etc., correct?
Thanks!
To be fair, different people see things differently. He said he had a background in UI, if this was working for Microsoft for example, then I have a different world view and no common language even to communicate with him. There are people that love Windows 8. I no longer try to understand them, just wish them luck.
He does have a point about the documentation being behind, but then like any good iOS app, you don't really need it.
The universal response to all those I have demonstrated iGlide to, even die-hard SYM and XCSoar fans, was, "wow - that looked easy!". In not a single instance has anyone said, "yeah, I can do that quicker and easier on my SYM/XCSoar....". The only complaint in the past has been, is it sunlight viewable? - and that has been largely addressed by the 6/6+.
I have not used SYM for many hours because it leaves such a bad taste in my mouth, however I have had more bugs and more crashing bugs on XCSoar and Winpilot, both running on an Avier, than on iGlide.
Old May 14th 15, 12:21 AM posted to rec.aviation.soaring
waremark
Thanks!
It would be much appreciated if one of you guys who prefer the iGlide and XCSoar UI to SYM could put up a video of setting a task on iGlide and/or XCS.. Would anyone be prepared to do that?
I find it much easier to set tasks and to change zoom levels on SYM than on XCS, but maybe I am missing the efficient ways to do things in XCS. I particularly like being able to customise the map screen of SYM fully flexibly to use my preferred combination of overlays and navboxes, and stats are very easy to find. For iGlide, I played with the lite version and it seemed hopeless, but I never looked at a manual and have never seen the full version so have not done it justice. However, since I have just changed my phone from iOs to a Galaxy S6 I am not going to pursue iGlide.
Old May 14th 15, 03:12 PM posted to rec.aviation.soaring
Bob Pasker
thanks everyone who decided it was better to question my bona fides or my experience than to answer the question! but after wading through that stuff, it seems like there's only 1 alternative, WinPilot, which I'll try, and I guess it behoves me to continue to push on the butterfly guys to fix the bugs and improve the experience.
Old May 14th 15, 05:00 PM posted to rec.aviation.soaring
Sean Fidler
Bob,
Please state the many bugs you mention. Especially the bugs butterfly acknowledged.
Otherwise, you're just a a drive by shooter ;-)
Sean
Old May 14th 15, 05:20 PM posted to rec.aviation.soaring
John Carlyle
As another happy iGlide user, I don't understand Bob Pasker "riddled with bugs" comment either. I know of some obscure bugs in the full version, but nothing that an owner of the lite version would encounter.
I echo the comments of the other iGlide users who have posted: put forward a list, Bob! Otherwise you're just trashing a good product without justification.
-John, Q3
iGlide Ben S Soaring 31 February 16th 20 05:14 AM
iPhone 6 Plus and iGlide jfitch Soaring 39 May 20th 15 02:07 AM
iGlide Mike Rinaldi Soaring 4 April 28th 15 01:48 AM
iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch) Sean Fidler Soaring 29 March 9th 15 04:24 AM
iglide [email protected] Soaring 1 June 2nd 13 06:07 PM
