Flarmview and Powerflarm Core Config File?
Old May 17th 15, 04:23 PM posted to rec.aviation.soaring
Papa3[_2_]
Default Flarmview and Powerflarm Core Config File?
I'm helping KS update his Powerflarm - firmware update to core and updated config files using the Config Tool from the Flarm Website. The update to the Powerflarm worked (solid green color), but the communication to the Flarmview stopped working.
I poked around and found the baudrate setting on the Flarmview is 38400 while the default setting on the config tool is 19400. Just for gits and shiggles I went into the manual settings using the config tool, updated the RJ connection to 38400, and it works.
So, before I claim victory, is there anything else that needs to be done to the "default" Flarm Config to make it work with a Flarmview. I did RTFM on the Flarmview, and it is pretty vague on what the communications protocol settings need to be...
P3
Old May 17th 15, 06:22 PM posted to rec.aviation.soaring
"Rainy days at a contest...."
You can look at a current (yesterday?) IGC log from the ship, it will have all the settings from the old config so you can compare to the new one. It was recently discussed here about "how to pull my old config before the update".
Old May 17th 15, 09:59 PM posted to rec.aviation.soaring
Papa3[_2_]
On Sunday, May 17, 2015 at 12:22:19 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
Yeah but... it looks like there is a new option for Communications Protocol that wasn't there before. At least that's what it looks like when you use the online Configuration Tool. I could be wrong.
Old May 18th 15, 01:09 PM posted to rec.aviation.soaring
Tango Eight
What I use:
# dataport configuration
# configure RJ-45 port for FlarmView 57
$PFLAC,S,NMEAOUT1,61
$PFLAC,S,BAUD1,5
and set (on flarmview) data rate to 57,600 baud.
It's not really necessary to set the mode -- I asked Uros about this and he says it is non-critical (so flarmview probably issues it's own mode setting command on the dataport). What *is* critical, as you have discovered is that the datarate set in flarmcfg.txt and on flarmview (in settings on flarmview) match.
Have fun at Mifflin.
-T8
Old May 18th 15, 11:51 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I don't recommend using the default settings. They are not ideal. I have
some tips for how to set the parameters in my PowerFLARM Tips document he
http://www.cumulus-soaring.com/flarm...FLARM-Tips.pdf
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
___________________________________
"Papa3" wrote in message
P3
PowerFLARM Core secondary FLARM antenna [email protected] Soaring 27 October 7th 14 02:53 PM
For Sale - Used PowerFLARM Core v1 Paul Remde Soaring 1 May 30th 14 04:09 AM
New FlarmView Flarm Config Menu? [email protected] Soaring 0 February 27th 14 06:06 PM
Powerflarm Brick/Core ADSB Range Sean F (F2) Soaring 3 September 5th 13 04:10 PM
