PowerFlarm and Mode C
Old May 28th 15, 01:58 PM posted to rec.aviation.soaring
Default PowerFlarm and Mode C
Wondering if someone here might be able to answer this question.
Does PowerFlarm need to have a good GPS fix before it will respond to a Mode C alert?
I have been flying with a Zaon MRX PCAS for years now. Many of those years I used the ZAON in parallel with PowerFlarm. My experience has been that the Zaon completely out performs the PowerFlarm in picking up Mode C signals.
This past weekend, with the glider in the hanger, the Zaon alerted to every single towplane departure. PowerFlarm scored a zero. Nothing.
So, while I know the ADSB antenna on the PowerFlarm does receive (ADSB targets and other Mode C targets) it should have had no trouble receiving the towplane signals with respect to signal strength as the towplane was only 300' away laterally.
As a result, I'm wondering if the PowerFlarm simply ignores all Mode C info if it has not been able to lock on to satelites OR if this has to do with the towplane being at the same altitude as my glider in the hanger. Is it the issue of "same altitude" that's been mentioned many times before where the PowerFlarm may ignore same altitude alerts.
This is the relevant portion of my config file...
$PFLAC,S,ADSBRANGE,65535
$PFLAC,S,ADSBVRANGE,1500
$PFLAC,S,PCASRANGE,7000
$PFLAC,S,PCASVRANGE,600
$PFLAC,S,MODEC,1
$PFLAC,S,OWNMODEC,1
$PFLAC,S,PCASCALIBRATION,30
$PFLAC,S,XPDR,2
$PFLAC,S,MODESALT,0
Either way, I will not be giving up my Zaon any time soon and I even went on ebay and picked up a backup since they are no longer in production. Fantastic little units.
Mark
Transponder: Mode-C or Mode-S? Morteza Ansari Soaring 27 April 17th 19 06:02 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 26th 12 12:58 AM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 02:50 AM
LK8000 Portrait mode in PC sim mode kirk.stant Soaring 22 December 28th 11 03:25 PM
PowerFLARM Mode S question kirk.stant Soaring 54 October 26th 10 03:51 PM
