Looking for recommendation on stick grip
Old June 7th 15, 11:41 PM posted to rec.aviation.soaring
Doug[_9_]
Default Looking for recommendation on stick grip
Want to upgrade the stick grip in my DG. Need ptt and cruise/climb but most of all need it to me comfy!
Doug
Old June 8th 15, 12:09 AM posted to rec.aviation.soaring
Have a look here.
http://www.gliderdesignparts.de/index.en.html
Randy
Old June 8th 15, 02:37 AM posted to rec.aviation.soaring
MNLou
I had one of these. http://www.rayallencompany.com/products/stickgrips.html
I really liked the large diameter of the stick. Very comfortable. Two finger contact was all I needed.
Lou
Old June 8th 15, 03:19 AM posted to rec.aviation.soaring
Bob T
Doug
Look at Pioneer Aviation out of Oregon.
Old June 8th 15, 05:22 AM posted to rec.aviation.soaring
Doug
After installing your "dream" stick, wrap it with bicycle handlebar tape. Multitude of color schemes which can be very snazzy! I also placed it on the trim control. Very comfy!
Old June 10th 15, 06:38 PM posted to rec.aviation.soaring
SF
Tennis Racquet grip tape works well. It's made for a good grip with sweaty palms. There are a lot of different tapes to choose from. It's cheap enough to change as often as you like.
SF
Old June 11th 15, 07:08 PM posted to rec.aviation.soaring
Charles Waldo
Doug
I second the Ray Allen stick grips....I've installed 2 of them.....
Chuck
Old June 11th 15, 07:51 PM posted to rec.aviation.soaring
Steve Koerner
I didn't like the grip on my '27 because it slips around and because it's too small in diameter. I turned a grip on the lathe out of Delrin plastic. I gave it three recessed set screws so it remains solidly in place. I used rubber coat plastic dip that you can get at any hardware store to give it a soft touch. This has worked well for me for several years.
It sounds like the tennis racket tape or handlebar tape might be a very good option too though. The commercially available grips that are referenced here look good if they have the right ID for your glider and if they stay put when you are low and desperate to make a skinny thermal work.
Old June 11th 15, 11:31 PM posted to rec.aviation.soaring
jfitch
On Thursday, June 11, 2015 at 10:51:26 AM UTC-7, Steve Koerner wrote:
I didn't like the grip on my '27 because it slips around and because it's too small in diameter. I turned a grip on the lathe out of Delrin plastic.. I gave it three recessed set screws so it remains solidly in place. I used rubber coat plastic dip that you can get at any hardware store to give it a soft touch. This has worked well for me for several years.
I have not seen a commercial grip that works with a Schleicher trim trigger..
Stick grip loose - help how do I attach it properly? Johan Pretorius Soaring 8 March 29th 14 11:51 PM
ME109 Stick Grip for sale Chris Jamesson Military Aviation 4 August 12th 10 07:10 PM
control stick (complete not only grip) from mig-21 papcio Aviation Marketplace 0 May 3rd 04 08:08 PM
B-8 stick grip buttons B2431 Military Aviation 4 December 16th 03 11:15 AM
FA Infinity Military Style Control Stick Grip Terry Ladouceur Home Built 3 October 8th 03 01:52 AM
