Solar power for the Zaon MRX collision avoidance system
Old September 3rd 15, 03:25 AM posted to rec.aviation.soaring
Soartech
Default Solar power for the Zaon MRX collision avoidance system
I know they stopped making the Zaon MRX but I think it is a great little device. I'm sure there are lots of us out there that use one. However it eats up a pair of AA batteries fairly quickly. I didn't want to connect it to my 12 V battery as that is just one more load on the system. Because the Zaon is on the glare shield and always in the sun I got the idea of using a mini solar panel attatched to it. I made an Instructable on how I did this:
http://www.instructables.com/id/Sola...ilar-small-el/
It works! Total cost is about $10.
Old September 3rd 15, 04:12 AM posted to rec.aviation.soaring
6PK
Had mine connected to the main without any issues for a few years. Than one day it would not power up. Next I installed the AA dry cells and it worked again a few times, after that it totally crapped out . Now it is paperweight. I wish there was somebody available to service them trough.
Old September 3rd 15, 05:55 PM posted to rec.aviation.soaring
Dan Marotta
EXCELLENT!
Mine is already connected to ship's power but it would clean up the
wiring up a bit to implement your solution. Thanks!
Dan Marotta
Old September 3rd 15, 08:51 PM posted to rec.aviation.soaring
On Thursday, September 3, 2015 at 11:55:20 AM UTC-4, Dan Marotta wrote:
EXCELLENT!
wiring up a bit to implement your solution.* Thanks!
Dan Marotta
I use a solar powered battery pack to power an android device; search Amazon.com, typically can find them for less than $20.
Old September 4th 15, 06:39 PM posted to rec.aviation.soaring
glidergreg
Had mine wired to ship power for years and never had a problem. Not using it anymore after installing FLARM with a LX Flarm display.
Old September 5th 15, 03:35 AM posted to rec.aviation.soaring
Bastoune
I had a problem with static in my radio with the Zaon connected to the ship's battery (squelch would go off). As a result, I went back to feeding AA batteries to the Zaon. Are those reporting not having problems with the Zaon connect to the 12v bus use some type of EMI filter? Thanks. B
Old September 5th 15, 04:27 AM posted to rec.aviation.soaring
Darryl Ramm
A few wraps of the power supply wire around a ferrite toroid and you should be fine. This was not an unusual issue to see with the MRX. Just grab a ferrite toroid from an electronics component supplier, or anywhere else you can, say something roughly like 3/8" OD x 3/8" to long 1/2" OD x 1/2" long.
Just sold my MRX and included the power supply cable with ferrite toroid on it for the new owner.
Old September 5th 15, 04:32 AM posted to rec.aviation.soaring
John Carlyle
The 2007 Zaon I had wired to my ASW-19 battery did not produce static on my Becker radio. The 2009 Zaon I wired into my LS-8 battery did make static on another Becker radio. As a sanity check I tried the 2007 Zaon in my LS-8 and found there was no static. For what it's worth...
-John, Q3
FS Zaon MRX Collision Avoidance bumper[_4_] Soaring 4 January 25th 12 06:08 AM
Zaon Traffic Avoidance and Flight Computers Jeffrey \PT\ Smith Soaring 5 September 16th 08 11:37 PM
Any pireps for PCAS MRX collision avoidance system? Mutts Piloting 21 July 3rd 07 03:20 PM
Any pireps for PCAS MRX collision avoidance system? Mutts Soaring 18 July 3rd 07 03:20 PM
PCAS - Portable Collision Avoidance System [email protected] Soaring 13 October 14th 06 08:21 PM
