Tow hook 182
Old October 22nd 15, 05:57 PM posted to rec.aviation.soaring
Default Tow hook 182
Looking for information on installing a tow hook on a 182, 337, STC,
Old October 22nd 15, 06:54 PM posted to rec.aviation.soaring
Frank Whiteley
Cessna drawings, if you're using a Schweizer hook.
http://www.wingsunlimitedtowhooks.co...allatio n.pdf
A TOST hook is another matter.
Old October 22nd 15, 07:01 PM posted to rec.aviation.soaring
Frank Whiteley
http://www.wingsunlimitedtowhooks.com/technical.html
They seem to have a hook of their own design, though I've never seen one in use.
The Seattle Glider Council C-182 has a TOST release installed according to their board minutes from April, 2012.
http://www.seattleglidercouncil.org/...nutes_0412.pdf
Contact Steve Northcraft for more details.
Old October 23rd 15, 08:47 PM posted to rec.aviation.soaring
Looks like a field approval.....need to find a kind open minded FSDO FAA Inspector who knows something about what he looking at and near death so he will no have to worry about it for much longer.
Old October 24th 15, 07:28 PM posted to rec.aviation.soaring
The good news is that it is much easier to get a 337 approved when it is based upon "approved data" such as the Cessna drawing linked above. This should be almost a non issue as a reviewing FAA inspector only has to verify conformance to data and does not have to make any judgments. They HATE to make judgements.
UH
Old October 26th 15, 02:07 AM posted to rec.aviation.soaring
Brian[_1_]
Why do you need a 337 if you are only install installing factory parts per factory drawings? You aren't modifing anything, just installing optional original equipment.
As I understand it this only requires a logbook entry by an A&P.
If you have to owner produce the parts, I don't think that changes anything as long as you can reasonably certify they match the factory drawing.
Brian
Old October 26th 15, 01:46 PM posted to rec.aviation.soaring
Brian
My read is that this is installation instructions for a Schweizer hitch not produced or provided by the factory. In any case it is an alteration where a 337 would be appropriate.
UH
Old October 26th 15, 02:39 PM posted to rec.aviation.soaring
Stephen Damon
Would not DAR be Abilene to sign off on tow,install and newer drawings. I believe there is a new towhook being developed by a USA company.
Compare/Contrast: CG hook on aerotow vs. CG hook on winch son_of_flubber Soaring 37 June 4th 12 11:40 PM
CG Hook for 1-26? [email protected] Soaring 1 October 29th 06 02:21 AM
Tow hook [email protected] Soaring 2 September 27th 06 03:16 AM
Tow Hook 337 for a 150-150 1JH Soaring 3 July 19th 05 07:35 PM
CG hook & Low Tow Ray Lovinggood Soaring 2 July 25th 03 07:20 AM
