Urethane Paint
Old November 11th 15, 02:15 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Urethane Paint
Any idea how much weight the urethane paint option adds to an 18 meter glider?
Old November 11th 15, 07:17 PM posted to rec.aviation.soaring
ND
not enough different from gel-coat to matter unless you are really heavy or really light.
Old November 12th 15, 01:56 AM posted to rec.aviation.soaring
jfitch
I answer that in a different way: if you go with gel coat, after your first refinish you will be a LOT lighter, but the weight will have come out of your wallet.
I would not consider buying a new glider that was not PU coated.
Old November 12th 15, 07:15 AM posted to rec.aviation.soaring
Jonathan St. Cloud
I was hoping to get a real number, i.e., 5, 10, 15 pounds, from someone with knowledge in this area. Not to be flippant nor disrespectful, but { not enough ... to matter, unless it does matter due to weight of the pilot} while thoughtful is really a null statement.
Old November 12th 15, 08:56 AM posted to rec.aviation.soaring
Depends on the amount of filler being used, if a thin layer of glass is added (~2kg for a whole glider) and how thick the original layer of gelcoat was. There are cases where there's no weight being added. But usually, around 5kg of additional weight can be expected.
Old November 12th 15, 01:54 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Thank you.
Old November 12th 15, 03:03 PM posted to rec.aviation.soaring
If urethane is requested, the manufacturer will most likely not use gelcoat in the mold and apply the urethane finish after assembling the parts. I know my Genesis was done this way. Ready to spray urethane is about 10# per gallon and it would take about 2 gallons.
JJ
Old November 12th 15, 04:01 PM posted to rec.aviation.soaring
JJ
Not true of current production yet John. Ships are molded with gelcoat, then filled and sanded, followed by finish paint. This avoids the million pinhole problem,
Maybe at some point they will spray primer in the mold, followed by lamination. That would require knowing and tracking which parts go on a painted ship, plus some process and quality controls.
FWIW
UH
Old November 13th 15, 01:31 AM posted to rec.aviation.soaring
Papa3[_2_]
I was just looking at this the other day for a project we're working on. Out of the 10 lbs or so per gallon, not all of that is solids; the solvents and some other additives will evaporate not to mention some lost to overspray. The percentage varies. It seems like 60% is a decent average, so 6lbs/gallon with about 2-3 gallons for a 15 meter glider? Call it 12-15 lbs?
P3
Old November 13th 15, 05:12 AM posted to rec.aviation.soaring
Andrzej Kobus
JJ
FWIW
UH
The gel coat sprayed in the mold is very thin. I had opportunity to look at my new glider in production, before it was moved to the paint shop.
urethane 2K paint [email protected] Soaring 1 February 4th 14 11:30 PM
Paint job W&B Dan Luke Owning 2 March 31st 07 12:03 AM
paint [email protected] Soaring 9 March 7th 06 09:22 PM
Paint Steve Owning 17 January 8th 06 08:54 AM
hi vis Paint Ben Haas Home Built 0 November 8th 03 02:58 PM
