I am looking for the weight and balance specs for the control surfaces for an ASW 19. Ailerons, elevator, and rudder. In theory, that ought to be in the maintenance manual. Which I don't have. If you have this manual, or even the specs for the control surfaces could you let me know? Thanks! John Swanson. Swanson43537. At. Yahoo dot com. |
Rudder without horn balance 6.61 to 7.50 lbs weight
6.94 to 9.55 in/lb max play 5.0 mm Rudder with horn balance, 7.28 to 8.16 lbs weight 7.81 to 10.41 in/lb max play 5.0 mm Elevator 4.36 to 6.39 lbs weight 5.21 to 7.81 in/lb max play 3.0 mm Aileron 6.61 to 7.94 lbs weight 7.59 to 9.33 in/lb max play 3.5 mm It is in the flight & operations manual for ASW 19b Regards Gordon |
Thanks! Do you have a copy of the manual? The manual disappeared from mine years ago before I owneed it. (but not the logbooks, thank goodness). The copy that everyone I've contacted so far has is only the flight manual, ending on page 19. The table of contents references the operations manual, but I've never been able to locate the missing pages.
You have e-mail
| Thread Tools | |
| Display Modes | |
| PA-32 Weight and Balance | John Doe | Owning | 14 | May 23rd 06 02:03 AM |
| L23 weight and balance | Tony Verhulst | Soaring | 5 | December 31st 05 02:54 AM |
| Weight & Balance DVD | jon | Home Built | 0 | October 8th 05 06:39 PM |
| Weight and Balance | Dale Larsen | Home Built | 2 | June 23rd 04 06:11 PM |
| Weight and balance.. | Bart | Rotorcraft | 9 | August 19th 03 03:57 AM |
