Jantar standard SZD-41A C.G. hook
Old November 23rd 15, 08:57 PM posted to rec.aviation.soaring
Žiga Munda
Default Jantar standard SZD-41A C.G. hook
Dne nedelja, 22. november 2015 18.40.54 UTC+1 je oseba Žiga Munda napisala:
Hello,
does someone have any information about C.G. towing hook instalation on SZD-41a.
All I know is that it should be mounted on landing gear.
Thank you.
So no one??
Old November 23rd 15, 09:08 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Hello,
Thank you.
So no one??
Have you checked with the jantar sailplanes Yahoo Group?
Old November 23rd 15, 10:18 PM posted to rec.aviation.soaring
Žiga Munda
Dne ponedeljek, 23. november 2015 21.08.32 UTC+1 je oseba Dan Daly napisala:
Hello,
Thank you.
So no one??
Thank you Dan I'll ckeck it. But I have to create Yahoo accout first.
Old November 24th 15, 03:00 AM posted to rec.aviation.soaring
Jock Proudfoot
http://www.greatlakesgliding.com/res...s/SZD%2041%20A
%20Flight%20Manual.pdf
" Towing hook : safety type TOST EUROPA 72 fixed in the fuselage
front part below the instrument panel. The hook is opened by means
of pulling the releasing handle and is closed automatically when the
handle is released due to the spring loading. During the winch
launching the rope is released when the rope angle reaches the
proper maximum value. The access to the hook is free when the
instrument panel and its base are disassembled. "
Cheers ...Jock
Jantar Standard Canopy jmarc Soaring 9 August 22nd 17 05:13 AM
Jantar Standard 2 & 3 handling Bryan Poehler Soaring 2 October 22nd 12 09:57 PM
Jantar Standard 41b N41BZ dam zaw Soaring 4 May 5th 11 01:01 PM
WTB: Standard Jantar or ASW-19 Kevin Christner Soaring 2 January 9th 11 06:51 PM
Jantar Standard 3 Miguel Lavalle Soaring 9 November 19th 03 01:01 AM
