Are there any motorgliders that can be logged as complex time?
Old December 21st 15, 08:46 PM posted to rec.aviation.soaring
Chris Snyder
Default Are there any motorgliders that can be logged as complex time?
Power pilots need 10 hours of complex time to earn a commercial rating...could it be done in a motorglider?
Retractable landing gear: CHECK
Controllable pitch prop: CHECK
Flaps: CHECK
Old December 21st 15, 08:55 PM posted to rec.aviation.soaring
Greg Delp
Flaps: CHECK
It's 10 hours required in an airplane not a glider. Uncheck
61.129(a) (3) (ii)
Old December 21st 15, 08:58 PM posted to rec.aviation.soaring
Darryl Ramm
Flaps: CHECK
Glider CHECK
Airplane NOT CHECK
Old December 21st 15, 10:31 PM posted to rec.aviation.soaring
Chris Snyder
Flaps: CHECK
Glider CHECK
Airplane NOT CHECK
I suppose that makes sense. I just got the notion after helping a friend with the motor brake on his Grob 103. It sounded pretty "complex" to operate while in-flight
Old December 22nd 15, 08:48 PM posted to rec.aviation.soaring
PGS
Flaps: CHECK
61.129(a) (3) (ii)
It would appear that a motor glider is indeed an airplane by the definitions.
Sec. 1.1 -- General definitions.
Airplane means an engine-driven fixed-wing aircraft heavier than air, that is supported in flight by the dynamic reaction of the air against its wings.
Aircraft means a device that is used or intended to be used for flight in the air.
Old December 22nd 15, 09:00 PM posted to rec.aviation.soaring
Darryl Ramm
Flaps: CHECK
61.129(a) (3) (ii)
What nonsense. A motorglider is registered as type glider, not an airplane.
Old December 22nd 15, 09:15 PM posted to rec.aviation.soaring
PGS
Flaps: CHECK
61.129(a) (3) (ii)
Yes, the FARs are full of "nonsense", what's your point? 61.129 does not say "type", it says airplane. The definition of airplane, according to the FARs is as mentioned above.
Old December 22nd 15, 09:20 PM posted to rec.aviation.soaring
Dan Marotta
Let us know how this works out for you.
Flaps: CHECK
61.129(a) (3) (ii)
Dan, 5J
Old December 22nd 15, 11:51 PM posted to rec.aviation.soaring
Casey Cox
Complex is as you state, but I'm wondering, does your motor glider have required lights and instrumentation required of airplanes and not just glider? I'm just asking.
Old December 23rd 15, 01:42 AM posted to rec.aviation.soaring
Darryl Ramm
What does that have to do with anything?
1. There are gliders and there are airplanes. You cannot meet experience requirements that require an airplane in a glider. Same question has been asked on r.a.s. before...
2. Airplanes do not have automatic light requirements, well not for VFR day at least. They have instrumentation requirements, which vary greatly depending on certified or experimental category. But that is all beyond irrelevant because of #1.
FLARM data format for contacts logged in IGC files [email protected] Soaring 3 August 11th 15 01:13 AM
Another hour logged Crash Lander[_2_] Piloting 18 March 14th 07 01:47 AM
Simulator for Complex time Steven Barnes Piloting 3 June 10th 06 07:56 PM
Mil Comms Logged in Florida, Friday 9 Apr 2004 AllanStern Military Aviation 0 April 10th 04 08:33 AM
NPR Woman with most logged flight hours vincent p. norris Piloting 6 January 25th 04 09:28 PM
