Ventus 3
Old December 24th 15, 06:26 PM posted to rec.aviation.soaring
Default Ventus 3
New pic on the SH site. First flight very soon.
Old December 24th 15, 09:57 PM posted to rec.aviation.soaring
Clay[_4_]
Default Ventus 3
What is the advantage of a polyhedral(?) wing?
Old December 24th 15, 10:14 PM posted to rec.aviation.soaring
Darryl Ramm
Default Ventus 3
Never being mistaken for a PW-5?
Old December 24th 15, 10:49 PM posted to rec.aviation.soaring
Default Ventus 3
One benefit of the greater dihedral outboard is that it has a longer moment to apply stablizing force which increases roll stability and roll response to yaw.
It also spreads the the flow field giving the effect of more span than a "flat" wing.
It allows the tip skids or wheels to be further inboard so the tips don't see ground loads.
It also looks cool.
UH
Old December 24th 15, 10:56 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Ventus 3
One aerodynamicist explained that it is a benefit in climb but has a penalty in cruise. It does look cool though. Word on the street it is a three year wait for a new Ventus
Old December 24th 15, 11:04 PM posted to rec.aviation.soaring
Clay[_4_]
Default Ventus 3
So you have 65 ft of wing in a 60 ft span (I'm exaggerating). Glider thinks it has 65 ft span. Runway lights must like it too. Not sure my 5'1" wife would.
Old December 24th 15, 11:26 PM posted to rec.aviation.soaring
jfitch
Default Ventus 3
On Thursday, December 24, 2015 at 1:49:12 PM UTC-8, wrote:
SNIP
It also puts a lot of wing very close to the ground on roll out. Closer than some rocks, weeds, etc. From experience owning a Duo.
Old December 24th 15, 11:29 PM posted to rec.aviation.soaring
JS
Default Ventus 3
Looks really cool.
Handles very nicely in the air.
More ground clearance with wings level.
(you may need to ask the wing runner to hold it higher)
With a low sun angle, there's always a reflection catching your attention.
Doesn't fit in the trailer as easily.
Pulling the tip out of the trailer, you're not on the center of gravity.
If there's any undulations or rocks, with a wing down the wing can hit outboard of the skid.
Not much to compare to a PW-5, unless V3 has a forward-hinged canopy.
Are the multiple angles easy to refinish?
Old December 25th 15, 01:46 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Ventus 3
Curiosity: why did he say that there's a benefit on the climb but penalty
during the cruise?
I've been told that using a multi-panel wing is better because the drag
from a dihedral break increases sharply as the angle increases: so much
so that a six panel wing performs better than a four panel wing of the
same span and area because of reduced drag from dihedral breaks. I don't
remember any speed effect being mentioned, hence my question.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 25th 15, 02:19 AM posted to rec.aviation.soaring
waremark
Default Ventus 3
Looks quite similar to the Arcus wing. The Arcus glides well at speed, although the wing loading cannot be particularly high.
Ventus 2c vs. 2cx noel.wade Soaring 19 June 27th 13 03:36 AM
FS: Ventus 2AX John C Soaring 0 September 8th 12 02:29 PM
Ventus bT BillT Soaring 2 March 19th 11 10:38 AM
ASW 27 vs. Ventus 2b Itsaplane[_2_] Soaring 5 August 9th 09 04:11 PM
Ventus B [email protected] Soaring 0 October 11th 06 08:43 PM
