An ADS-B In Question
Old January 10th 16, 08:08 PM posted to rec.aviation.soaring
Dan Marotta
Default An ADS-B In Question
Hopefully Darryl will respond to this but anyone with the knowledge will
be appreciated.
I have a home-grown ADS-B system consisting of a Raspberry Pi 2 and a
couple of software defined radios feeding Avare on my smart phone. I
have line of sight to the ADS-B tower on top of Sandia Peak, on the east
side of Albuquerque. I see a number of 1090ES targets around the ABQ
area, one at 10,400PA', one at 8,200PA' over SAF, several in the high
30s to low 40s pressure altitude. But I don't see any targets very far
away from Albuquerque.
Is it that only targets within some volume are being transmitted through
the tower within view or am I simply receiving the 1090ES transmissions
directly from the aircraft? I think this may be the case as I don't see
and aircraft on my display that I couldn't see with binoculars from my
house.
When I first turned on the system I saw some aircraft that appeared to
be in the traffic pattern at ABQ and, from where I live on the east side
of the mountains, their transmissions would be blocked by the
mountains. I speculate that there was an ADS-B Out aircraft flying
relatively low near my house and I was receiving TIS-B transmissions
meant for him. I also saw ADS-B weather that day and there were a lot
of snow storms up and down the Rockies.
Dan, 5J
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 07:39 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 02:11 AM
CPL Question William Snow Piloting 2 February 16th 05 02:49 AM
FAR question Roger Worden Soaring 3 January 10th 05 07:22 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
