LS-3a Polar Info. Wanted.
Old January 20th 16, 06:05 PM posted to rec.aviation.soaring
Eric Nielsen
Default LS-3a Polar Info. Wanted.
I've recently purchased an LS-3a. My P.O.H. does not include a Polar Curve Graph, so I'm having difficulty finding difficulty in finding speeds for Min. sink, speeds to fly in Headwind/Tailwind, and in sink. Any Help is appreciated.
Old January 20th 16, 06:28 PM posted to rec.aviation.soaring
The Johnson flight tests, available from the Soaring magazine archives, have the information you need.
Good Luck
UH
Old January 20th 16, 06:29 PM posted to rec.aviation.soaring
Johnson test... http://www.postfrontal.com/PDF/prove_alianti/LS3a.pdf
Better copy on SSA.....
Old January 20th 16, 07:38 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Paul at Cumulus Soaring has a polar page including LS3. http://www.cumulus-soaring.com/polars.htm Excellent resource.
You can cross-check the LS3a polar to make sure it is close enough (it should be).
Old January 21st 16, 02:26 PM posted to rec.aviation.soaring
Gianni Isotope
I'm not sure if it is helpful, but the uploaded files collection of the LS gliders forum in Yahoo Groups (https://groups.yahoo.com/neo/groups/LS-gliders/info) has copies of polar graphs from an LS-3 (not 3a) POH.
Laister LP-49 TE and polar info Jim Meade Soaring 5 June 8th 18 09:14 PM
Wanted: Flapped polar curve of a ventus ct Jurgen decraemer Soaring 2 December 9th 09 10:45 AM
HP-18 Polar info jim Soaring 2 September 25th 09 04:26 PM
LX1600 polar info Chris Davison Soaring 3 August 5th 06 10:30 PM
Discus Info Wanted Scott Soaring 0 March 9th 04 06:59 AM
