Searching for annual aviation statics, USA and world...
Old January 29th 16, 03:53 PM posted to rec.aviation.soaring
Dave Nadler
Default Searching for annual aviation statics, USA and world...
Hi All - I' searching for some stats to put things in context for the SSA presentation. Much obliged if anyone can provide sources for:
Annual stats from 1950s forward, USA and world totals:
- IFR flight-plans served
- active aircraft
- aircraft produced including GA (and LSA or as Europeans call them ultralights)
- TCAS-equipped aircraft
Thanks in advance for any help,
Best Regards, Dave
Old January 29th 16, 03:57 PM posted to rec.aviation.soaring
- active aircraft
Best Regards, Dave
I would have to guess AOPA & IAOPA would cover some of that. FAA (if you can dig through the info) will also have a lot of that for the US.
Old January 29th 16, 04:01 PM posted to rec.aviation.soaring
Dave Nadler
On Friday, January 29, 2016 at 10:57:51 AM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote:
I would have to guess...
Aaarrgggg....
AOPA did not (yes, I'm a member, and called and talked to a "stats guy").
FAA and DOT sites have lots of info but I could not locate the info I asked for above...
Thanks in advance for any sources!
Best Regards, Dave
Old January 29th 16, 06:27 PM posted to rec.aviation.soaring
Aaarrgggg....
Best Regards, Dave
These would be great... http://www.cityofcharlevoix.org/city...dixB_FINAL.pdf
Done by these guys.... http://www.avdataspecialists.com/
They only go back to 2005 though. And it's a service, thus money.
Old January 29th 16, 09:12 PM posted to rec.aviation.soaring
- active aircraft
Best Regards, Dave
The GAMA Databook has plenty of data going back quite a way. You go pretty far back in their archive to get numbers from the 70's, though maybe not too much further than that: http://gama.aero/files/GAMA_2014_Dat...-%20LowRes.pdf It includes information on IFR operations.
Also, the GA and Part 135 survey provides quite a bit of information that may be useful to you: https://www.faa.gov/data_research/av...eral_aviation/ Just understand that it is survey data, so it is 'approximate'.
Don't know what your presentation is about, but I put together a presentation about the characteristics of GA for work. If you need that type of data, send me an email.
You're Invited to the 4th Annual Rec.Aviation Party(s)! Jay Honeck Owning 23 July 3rd 06 07:11 PM
You're Invited to the 4th Annual Rec.Aviation Party(s)! Jim Burns Piloting 6 July 1st 06 03:08 AM
Aft fuselage statics [email protected] Soaring 5 March 16th 06 04:09 AM
2005 annual rec.aviation flyin Jay Honeck Piloting 5 February 9th 05 12:24 AM
Use of Statics Robin Birch Soaring 2 December 28th 03 05:17 PM
