Grob 103 - Main Tire Tube Type
Old March 24th 16, 07:22 PM posted to rec.aviation.soaring
Default Grob 103 - Main Tire Tube Type
Trying to order a 600 x 6 Tube for the main tire on a Grob 103 Twin II, and need to know which tube I need to order (which valve is used? ) There are several different types?
http://wingsandwheels.com/aircraft-parts/tubes.html
These are the valve variations:
TR-87 short valve bent out 90 degrees from center (left)TR-67 vs TR-87
TR-67 long valve bent out 90 degrees from center (right)
TR-20 straight valve
90 valve bent out 90 degrees from center
45 valve bent out 45 degrees from center
Thanks for the help!
Tim Hanke
Adirondack Soaring
Saratoga Springs, NY
Old March 25th 16, 12:29 AM posted to rec.aviation.soaring
I have a 600 X 6 tire and tube off a G-103 and it has a straight filler tube located 1" from center line and it is 1.75" tall.
JJ
Old March 25th 16, 02:26 AM posted to rec.aviation.soaring
Bill T
The previous owner of W&W could tell you what you needed. That "corporate knowledge " did not transfer with the company,
BillT
Old March 25th 16, 05:00 AM posted to rec.aviation.soaring
Larry Suter
According to my records our club orders
"TU 600-6 Short Tube, Short 90 Stem TR-87" tubes from Desser for our Grob 103 main wheels.
Larry
Northern California Soaring Association
Tim Hanke
Adirondack Soaring
Old March 25th 16, 01:06 PM posted to rec.aviation.soaring
Thanks Larry
Larry
Tim Hanke
Adirondack Soaring
Old March 25th 16, 08:51 PM posted to rec.aviation.soaring
Eric Munk
Note that there's also a fair number of Twin Astirs out there with the
optional mod for a 5.00x5 wheel. Mine is one of them.
At 12:06 25 March 2016, wrote:
Thanks Larry
Grob
103 main wheels.
Larry
II,
TR-87
Tim Hanke
Adirondack Soaring
PW-5 Main Tire Pressure? JohnDeRosa Soaring 3 June 23rd 13 10:38 AM
What's the best way to install a new tire tube ? [email protected] Soaring 14 March 9th 09 12:46 PM
FA: Aircraft tire and tube, New, 500 x 5 [email protected] Home Built 1 February 3rd 06 11:42 PM
FA: Aircraft tire and tube, New, 500 x 5 [email protected] Aviation Marketplace 1 February 3rd 06 11:42 PM
Puchacz Tire and Tube [email protected] Soaring 1 September 14th 04 07:17 AM
