SimplyKool Canopy Cover Discount
Old April 1st 16, 01:47 PM posted to rec.aviation.soaring
Default SimplyKool Canopy Cover Discount
FYI, SimplyKool is running a 10% off Spring Sale through April on all silver reflective canopy covers. Ask your dealer to add it to your order or buy direct from the manufacturer on eBay www.ebay.com/itm/130723757512
Old April 1st 16, 05:53 PM posted to rec.aviation.soaring
vontresc
You have a pattern for a Libelle?
Old April 1st 16, 07:23 PM posted to rec.aviation.soaring
Since a canopy cannot be latched closed while a stretch-fit cover is on, we cannot make covers for unhinged canopies like the Libelle.
Old April 1st 16, 11:17 PM posted to rec.aviation.soaring
AS
Try Vertigo Covers in the UK. They were represented at the SSA convention and are easy to work with.
http://vertigocovers.co.uk/canopy.html
Uli
Old April 3rd 16, 01:56 AM posted to rec.aviation.soaring
Paul Remde
Hi Pete,
Franklin Fabrication has a Canopy Cap for Libelles.
http://www.cumulus-soaring.com/canopycap.htm#Sailplanes
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
______________________________
"vontresc" wrote in message
Old April 3rd 16, 01:57 AM posted to rec.aviation.soaring
Paul Remde
Hi,
I have added the SimplyKool 10% OFF sale to my web site he
http://www.cumulus-soaring.com/simplykool.htm
Good Soaring,
Paul Remde
__________________________________
Old April 3rd 16, 07:33 AM posted to rec.aviation.soaring
xcnick
On Saturday, April 2, 2016 at 4:57:19 PM UTC-7, Paul Remde wrote:
Hi,
You don't have a comparison of the two brands of caps you carry on the website. Perhaps you can add something here. I have a side canopy and am particularly interested in how each would work on a Discus.
Old April 3rd 16, 05:23 PM posted to rec.aviation.soaring
Hi,
Allow me, though I may be biased. On a Discus Franklyn utilizes some straps and buckles while SimplyKool,IMO, is simpler to use because it is tailored for the hinges. I have a Discus and it was one of the first covers we made
The two manufacturers are more similar on the other models with the exception that SimplyKool has a "covered wagon" back on all its custom fit models and additionally the whole cover can be snugged up with the adjustable drawstring if desired. Franklyn doesn't have a covered wagon on their models so they offer an optional "Sun Shield" at extra cost.
Paul has some detail pictures on his site of both:
CanopyCap http://www.cumulus-soaring.com/misc/...Cap-side-2.jpg and SimplyKool http://www.cumulus-soaring.com/simpl...mplyKool-5.jpg
-Jim
Old April 4th 16, 02:57 PM posted to rec.aviation.soaring
Hi,
CanopyCap http://www.cumulus-soaring.com/misc/...Cap-side-2.jpg and SimplyKool http://www.cumulus-soaring.com/simpl...plyKool-5..jpg
-Jim
Actually there are many differences -
The space between fuselage and canopy rail on Schempp-Hirth gliders is very small. The Franklin Fabrication Canopy Cap is designed to place minimal fabric into this space. The other brand's design forces large amounts of gathered material and elastic into this space which puts stress on the hinges and can crack the gel coat there.
The Canopy Cap Sun Shield option is the most effective at blocking the reflections that can cause cockpit fires in gliders with forward hinge canopies.
Franklin Fabrication uses 30 different patterns to achieve a perfect tailored fit for most gliders.
Quality and construction on the Canopy Cap is superior. The fabric is thicker and the elastic is 4X wider. They are produced on industrial machines using three different types of stitches that accommodate the stretch fabric (not just a straight stitch which WILL pop when the fabric is stretched). Also they include a quality storage bag at no extra charge.
Franklin Fabrication supports the U.S. soaring products dealers. They are not available on FleaBay.
And the strap and buckles on my Franklin cover for my Schempp-Hirth glider never really worked right (buckle wouldn't release from itself) and broke within the first few uses, and now the cover is not easy to fit on the canopy. I'm going to try the Canopy Cap also and report back...
Old April 4th 16, 02:59 PM posted to rec.aviation.soaring
Hi,
-Jim
sorry... going to try the SimplyKool and report back. And yes, I bought it off "Fleabay"
ASW27 Canopy Cover pat Soaring 2 September 13th 11 03:46 AM
SimplyKool Metallic Canopy Covers Paul Remde Soaring 5 August 20th 11 03:27 PM
Cloth For Canopy Cover John[_27_] Soaring 9 August 14th 10 01:16 AM
W&W canopy cover? Gary Emerson Soaring 5 April 1st 08 08:19 AM
canopy cover material? ken ward Soaring 0 March 8th 04 06:23 AM
